Ana içeriğe geç
Acer Aspire One D257 HDD Replacement
Claes
Claes ve 2 diğer katkıda bulunanlar
En son August 30, 2017 tarihinde güncellendi
10 dakika
Orta
İşlem Görüntüleri
Topluluk-Katkılı Kılavuz
Describes how you replace the HDD from the netbook.
Neye ihtiyacın var
Aletler
Daha fazlasını göster…
  1. Acer Aspire One D257 HDD Replacement, Battery: adım 1, 1 resimden 1.
    • Put the netbook, so the back side is upwards.
  2. Acer Aspire One D257 HDD Replacement: adım 2, 1 resimden 1.
    • Push the right lock to the right so the red filed is visible on the left.
  3. Acer Aspire One D257 HDD Replacement: adım 3, 1 resimden 1.
    • Now move the left lock which is spring loaded to the leftand keep it there. Then with the other hand remove the battery by pulling down.
    • When reassembeling the new battery push it up into the netbook and do lock the right by moving it to the left so the red field disappears.
  4. Acer Aspire One D257 HDD Replacement, Keyboard: adım 4, 2 resimden 1. Acer Aspire One D257 HDD Replacement, Keyboard: adım 4, 2 resimden 2.
    • Open the lid othe the netbook. Use the Jimmy from the upper left corner of the keyboard. Put it between the keyboard and th casing and move it to the right. It might help to use a metal spudger to push in the pins holding the keyboard in place.
    • Then move down along the sides where there is one pin on each side. After that twist the keyboard towards you.
  5. Acer Aspire One D257 HDD Replacement: adım 5, 1 resimden 1.
    • Now open the brown connector so the flat cable is loose. Then you can remove the keyboard.
  6. Acer Aspire One D257 HDD Replacement, Acer Aspire One D257 opening the hatch: adım 6, 1 resimden 1.
    • Remove the 5 screws marked with "Door".
  7. Acer Aspire One D257 HDD Replacement: adım 7, 2 resimden 1. Acer Aspire One D257 HDD Replacement: adım 7, 2 resimden 2.
    • Use a spudger or flat screwdriver to push down the hatch where it is marked "Door release".
    • Now you can carfully remove the hatch.
    • When reassembling the hatch look that the noses are aimed at the appropriate holes in the case, then you can press down the rest of the hatch onto the netbook.
  8. Acer Aspire One D257 HDD Replacement, Harddisk Drive: adım 8, 1 resimden 1.
    • The hard disk drive is under the lighgrey casing and not screw to it.
  9. Acer Aspire One D257 HDD Replacement: adım 9, 1 resimden 1.
    • Now push the HDD downwards with the finger through the hole.
  10. Acer Aspire One D257 HDD Replacement: adım 10, 1 resimden 1.
    • Remove the Sata connector from the hard disk drive.
    • Now you can connect any Sata-HDD or SDD.
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
Bu çevirmenlere özel teşekkürler:
de en
100%
Bu çevirmenler dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
Claes
3.422 İtibar
6 adet Kılavuz yazıldı
Ekip
Master Techs Master Techs üyesi
Community
327 Üyeler
1.678 adet Kılavuz yazıldı
7Kılavuz Yorumları
very helpful
many thanks
Pablo Tassinari - Yanıt
You are missing a few steps.
Arctic W. Fox - Yanıt
@Arctic W. Fox What steps are you missing?
Claes - Yanıt
The HD is removed through the back - there are about 5 screws (marked "Door") that need to be removed once the keyboard is removed. :-)
basestationzero - Yanıt
Thanks for the feedback, I added the steps at least in the German Guide do not know how long it takes for the steps to show up in the translated English Version.
Claes -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 29
Her zaman: 12,273
