Ana içeriğe geç
Acer Aspire R7 Battery Replacement
Neye ihtiyacın var
  1. Acer Aspire R7 Battery Replacement, Cover: adım 1, 1 resimden 1.
    • Shut down the laptop and disconnect the power cord.
    • Failing to disconnect or shut down the laptop could result in damage to the laptop or a shock hazard.
    • Turn the laptop over.
  2. Acer Aspire R7 Battery Replacement: adım 2, 3 resimden 1. Acer Aspire R7 Battery Replacement: adım 2, 3 resimden 2. Acer Aspire R7 Battery Replacement: adım 2, 3 resimden 3.
    • Remove seven 10 mm T7 screws.
    • Remove four 6 mm T7 screws.
    • Use the blue plastic opening tool to carefully remove both rubber pads which cover the four remaining screws.
    • Remove the remaining four 10 mm T7 screws.
  3. Acer Aspire R7 Battery Replacement: adım 3, 1 resimden 1.
    • Carefully lift the cover upwards.
    • If the cover seems stuck, use a spudger tool to pry the sides.
  4. Acer Aspire R7 Battery Replacement, Battery: adım 4, 2 resimden 1. Acer Aspire R7 Battery Replacement, Battery: adım 4, 2 resimden 2.
    • Locate the battery ribbon connector
    • Remove the ribbon cable attaching the battery to the motherboard by carefully pulling it outwards
    • When using the spudger be careful around the motherboard as it can easily be damaged
  5. Acer Aspire R7 Battery Replacement: adım 5, 3 resimden 1. Acer Aspire R7 Battery Replacement: adım 5, 3 resimden 2. Acer Aspire R7 Battery Replacement: adım 5, 3 resimden 3.
    • Remove the three 4.5mm #00 Phillips screws attaching the battery to the motherboard
    • Push the 4 retaining clips away from the battery
    • Carefully lift the battery from the motherboard
Sonuç
12 farklı kişi bu kılavuzu tamamladı.
F Fernandez
435 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 3-4, Hickman Winter 2015 USF Tampa, Team 3-4, Hickman Winter 2015 üyesi
USFT-HICKMAN-W15S3G4
4 Üyeler
7 adet Kılavuz yazıldı
6 Yorum
great instructions
amaryheart7777777 - Yanıt
What is the battery reference for replacement ?
skalpinou - Yanıt
which battery model do I purchase for replacing on an Acer Aspire R?
Eddie - Yanıt
hey how do you want då sel it for
Alex santos - Yanıt
super tuto
Thanks
P.S : A have add a short comment on step 2.
Bests regards
Anthymoine - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 10
Son 30 gün: 39
Her zaman: 41,251
