Ana içeriğe geç
Acer Aspire Switch 10 SW5-012-18MY Display Replacement
Neye ihtiyacın var
  1. Acer Aspire Switch 10 SW5-012-18MY Display Replacement, Battery: adım 1, 2 resimden 1. Acer Aspire Switch 10 SW5-012-18MY Display Replacement, Battery: adım 1, 2 resimden 2.
    • Remove the tablet from the keyboard.
    • You will not be needing the keyboard for this guide.
  2. Acer Aspire Switch 10 SW5-012-18MY Display Replacement: adım 2, 3 resimden 1. Acer Aspire Switch 10 SW5-012-18MY Display Replacement: adım 2, 3 resimden 2. Acer Aspire Switch 10 SW5-012-18MY Display Replacement: adım 2, 3 resimden 3.
    • Use the opening tool to open the back cover. The opening tool should fit under the cover if you place it above the power button.
    • Lift this side of the back cover once the opening tool is inside the device.
    • Use the opening tool and your hands to gradually work around the edges of the cover.
  3. Acer Aspire Switch 10 SW5-012-18MY Display Replacement: adım 3, 2 resimden 1. Acer Aspire Switch 10 SW5-012-18MY Display Replacement: adım 3, 2 resimden 2.
    • Lift the back cover off of the device with your hands.
    • You will need to use some force to pull off the back cover.
  4. Acer Aspire Switch 10 SW5-012-18MY Display Replacement: adım 4, 2 resimden 1. Acer Aspire Switch 10 SW5-012-18MY Display Replacement: adım 4, 2 resimden 2.
    • Remove the piece of black, thin tape that is attached to the circuit board closest to the power button.
  5. Acer Aspire Switch 10 SW5-012-18MY Display Replacement: adım 5, 3 resimden 1. Acer Aspire Switch 10 SW5-012-18MY Display Replacement: adım 5, 3 resimden 2. Acer Aspire Switch 10 SW5-012-18MY Display Replacement: adım 5, 3 resimden 3.
    • Use the opening tool to lift the ZIF connector holding the ribbon cable in place on the circuit board.
    • Pull out the ribbon cable from the circuit board. This cable should have the word "Audio" on it.
  6. Acer Aspire Switch 10 SW5-012-18MY Display Replacement: adım 6, 3 resimden 1. Acer Aspire Switch 10 SW5-012-18MY Display Replacement: adım 6, 3 resimden 2. Acer Aspire Switch 10 SW5-012-18MY Display Replacement: adım 6, 3 resimden 3.
    • Remove the piece of thin, black tape that is attached to the circuit board on the other side of the battery.
    • Use the opening tool to lift the black ZIF connector holding the ribbon cable in place.
  7. Acer Aspire Switch 10 SW5-012-18MY Display Replacement: adım 7, 2 resimden 1. Acer Aspire Switch 10 SW5-012-18MY Display Replacement: adım 7, 2 resimden 2.
    • Partially remove the piece of black tape that is holding the bundled cable connector to the battery in place.
    • Pull on the battery's bundled cable connector to unplug it from the circuit board.
  8. Acer Aspire Switch 10 SW5-012-18MY Display Replacement: adım 8, 1 resimden 1.
    • Using the Phillips #000 screwdriver, remove the 3 mm screw that is holding the battery in place.
  9. Acer Aspire Switch 10 SW5-012-18MY Display Replacement: adım 9, 1 resimden 1.
    • Gently remove the ribbon cable from the battery.
  10. Acer Aspire Switch 10 SW5-012-18MY Display Replacement: adım 10, 2 resimden 1. Acer Aspire Switch 10 SW5-012-18MY Display Replacement: adım 10, 2 resimden 2.
    • Carefully remove the battery from the device by lifting it up.
  11. Acer Aspire Switch 10 SW5-012-18MY Display Replacement, Motherboard: adım 11, 1 resimden 1.
    • Now that the battery is removed, it is time to remove the remaining ribbon cables and connectors (marked in red) from the motherboard.
  12. Acer Aspire Switch 10 SW5-012-18MY Display Replacement: adım 12, 2 resimden 1. Acer Aspire Switch 10 SW5-012-18MY Display Replacement: adım 12, 2 resimden 2.
    • Remove motherboard ribbon cable and slide the opening tool under the cable lock.
    • Flip the cable lock up.
  13. Acer Aspire Switch 10 SW5-012-18MY Display Replacement: adım 13, 2 resimden 1. Acer Aspire Switch 10 SW5-012-18MY Display Replacement: adım 13, 2 resimden 2.
    • Pinch the ribbon cable and slowly remove it from the port.
  14. Acer Aspire Switch 10 SW5-012-18MY Display Replacement: adım 14, 1 resimden 1.
    • Remove the charging port cable from the motherboard using the opening tool. Remove them in the same fashion you removed the other cables.
  15. Acer Aspire Switch 10 SW5-012-18MY Display Replacement: adım 15, 2 resimden 1. Acer Aspire Switch 10 SW5-012-18MY Display Replacement: adım 15, 2 resimden 2.
    • Remove the Wifi cables.
    • Slide the opening tool under the cables and pop them out of their connectors.
  16. Acer Aspire Switch 10 SW5-012-18MY Display Replacement: adım 16, 2 resimden 1. Acer Aspire Switch 10 SW5-012-18MY Display Replacement: adım 16, 2 resimden 2.
    • Remove the webcam ribbon cable.
    • Slide the opening tool underneath the port lock and pop it upward.
    • Remove the webcam, if possible, putting it safely aside.
  17. Acer Aspire Switch 10 SW5-012-18MY Display Replacement: adım 17, 2 resimden 1. Acer Aspire Switch 10 SW5-012-18MY Display Replacement: adım 17, 2 resimden 2.
    • Using the Phillips #000 screwdriver remove the three 3 mm screws, circled in red, on the motherboard.
  18. Acer Aspire Switch 10 SW5-012-18MY Display Replacement: adım 18, 1 resimden 1.
    • With all screws and ribbon cables removed, it is now possible to remove the motherboard from the tray.
    • Slide the opening tool under the motherboard.
    • Lift up to remove.
  19. Acer Aspire Switch 10 SW5-012-18MY Display Replacement: adım 19, 1 resimden 1.
    • You have removed the motherboard from the laptop.
  20. Acer Aspire Switch 10 SW5-012-18MY Display Replacement, Display: adım 20, 3 resimden 1. Acer Aspire Switch 10 SW5-012-18MY Display Replacement, Display: adım 20, 3 resimden 2. Acer Aspire Switch 10 SW5-012-18MY Display Replacement, Display: adım 20, 3 resimden 3.
    • Use the Phillips #000 screwdriver to remove the three 3 mm screws on the circuit board.
    • Disregard the battery in the pictures since the battery is already removed at this point in this guide.
  21. Acer Aspire Switch 10 SW5-012-18MY Display Replacement: adım 21, 2 resimden 1. Acer Aspire Switch 10 SW5-012-18MY Display Replacement: adım 21, 2 resimden 2.
  22. Acer Aspire Switch 10 SW5-012-18MY Display Replacement: adım 22, 1 resimden 1.
    • Since the display assembly is part of the motherboard tray, you will need to source a new display and do the steps within this guide in reverse to reassemble.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
1Rehber Yorum
Where exactly is the display on the motherboard?
Ashley Thurston - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 33
Her zaman: 2,827
