Ana içeriğe geç
Acer Aspire Switch 10 SW5-012-18MY Power Button Replacement
Neye ihtiyacın var
  1. Acer Aspire Switch 10 SW5-012-18MY Power Button Replacement, Power Button: adım 1, 2 resimden 1. Acer Aspire Switch 10 SW5-012-18MY Power Button Replacement, Power Button: adım 1, 2 resimden 2.
    • Remove the tablet from the keyboard.
    • You will not be needing the keyboard for this guide.
  2. Acer Aspire Switch 10 SW5-012-18MY Power Button Replacement: adım 2, 3 resimden 1. Acer Aspire Switch 10 SW5-012-18MY Power Button Replacement: adım 2, 3 resimden 2. Acer Aspire Switch 10 SW5-012-18MY Power Button Replacement: adım 2, 3 resimden 3.
    • Use the opening tool to open the back cover. The opening tool should fit under the cover if you place it above the power button.
    • Lift this side of the back cover once the opening tool is inside the device.
    • Use the opening tool and your hands to gradually work around the edges of the cover.
  3. Acer Aspire Switch 10 SW5-012-18MY Power Button Replacement: adım 3, 2 resimden 1. Acer Aspire Switch 10 SW5-012-18MY Power Button Replacement: adım 3, 2 resimden 2.
    • Lift the back cover off of the device with your hands.
    • You will need to use some force to pull off the back cover.
  4. Acer Aspire Switch 10 SW5-012-18MY Power Button Replacement: adım 4, 2 resimden 1. Acer Aspire Switch 10 SW5-012-18MY Power Button Replacement: adım 4, 2 resimden 2.
    • Remove the piece of black, thin tape that is attached to the circuit board closest to the power button.
  5. Acer Aspire Switch 10 SW5-012-18MY Power Button Replacement: adım 5, 3 resimden 1. Acer Aspire Switch 10 SW5-012-18MY Power Button Replacement: adım 5, 3 resimden 2. Acer Aspire Switch 10 SW5-012-18MY Power Button Replacement: adım 5, 3 resimden 3.
    • Use the opening tool to lift the ZIF connector that is holding the ribbon cable in place.
    • Pull out the ribbon cable from the circuit board. This cable should have the word "Audio" on it.
  6. Acer Aspire Switch 10 SW5-012-18MY Power Button Replacement: adım 6, 3 resimden 1. Acer Aspire Switch 10 SW5-012-18MY Power Button Replacement: adım 6, 3 resimden 2. Acer Aspire Switch 10 SW5-012-18MY Power Button Replacement: adım 6, 3 resimden 3.
    • Use the Phillips #000 screwdriver to remove the three 3 mm screws on the circuit board.
  7. Acer Aspire Switch 10 SW5-012-18MY Power Button Replacement: adım 7, 2 resimden 1. Acer Aspire Switch 10 SW5-012-18MY Power Button Replacement: adım 7, 2 resimden 2.
    • Carefully remove the circuit board from the device. The power button is located on this piece.
    • To replace the power button on this piece, please go to the page How To Solder and Desolder Connections.
Sonuç
Grecia Corrada
1.134 İtibar
6 adet Kılavuz yazıldı
Ekip
Baylor, Team S3-G3, Williams Spring 2018 Baylor, Team S3-G3, Williams Spring 2018 üyesi
BU-WILLIAMS-S18S3G3
3 Üyeler
7 adet Kılavuz yazıldı
1Rehber Yorum
I have broken ZIF connector to hold power ribbon cable,can i repair this or change board?
Milan Štos - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 19
Her zaman: 3,197
