Ana içeriğe geç
Acer Aspire V15 V3-575-50TD Disassembly
Netmammal
Netmammal ve 2 diğer katkıda bulunanlar
En son June 10, 2019 tarihinde güncellendi
Tahmin yok
Orta
Daha Fazla Görsel Gerekli
Topluluk-Katkılı Kılavuz
Neye ihtiyacın var
iFixit bu bağlantılar üzerinden satın aldığınızda komisyon kazanır.
    • This thing is intentionally designed to be difficult to work on, no doubt to prevent or at minimum, punish smarties from buying this and upgrading it.
    • Sorry for no photos. I figured this was better than nothing until I have time.
    • Remove the 18 screws. eject the optical drive with a paperclip, and then pull the whole thing straight out. It may not want to come, but it will come, you are sliding it out of a SATA connector. It is not screwed in to anything (as long as you removed ALL 18 screws.)
    • After optical drive is out, remove three more screws now visible/accessible in the optical drive opening.
    • You're still not out of the woods. Now start prying bottom from top. Be careful: there is a cable connecting the bottom cover to the motherboard.
    • If you start at the optical drive end, it will probably be easier than it was for me (I thought the optical drive was still bolted in, and had to half remove cover before freeing it.)
    • Be very careful to unhook the connector between the cover and the main board before separating bottom by more than an inch or two.
    • I struggled to get the cover "over" the usb & other ports, but if you start from the other end, it may be easier.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Netmammal
2.277 İtibar
4 adet Kılavuz yazıldı
Ekip
Local Hero Tech Support Local Hero Tech Support üyesi
Business
1 Üye
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 25
Her zaman: 1,633
