Ana içeriğe geç
Acer Aspire V5-572, V5-572G HDD Replacement
Neye ihtiyacın var
Videoya Genel Bakış
  1. Acer Aspire V5-572, V5-572G HDD Replacement, Bottom Cover: adım 1, 1 resimden 1.
    • Switch-off the Laptop.
    • Remove the seventeen Philips #0 screws.
  2. Acer Aspire V5-572, V5-572G HDD Replacement: adım 2, 1 resimden 1.
    • If there is a plastic storage tray in the laptop, remove it.
  3. Acer Aspire V5-572, V5-572G HDD Replacement: adım 3, 3 resimden 1. Acer Aspire V5-572, V5-572G HDD Replacement: adım 3, 3 resimden 2. Acer Aspire V5-572, V5-572G HDD Replacement: adım 3, 3 resimden 3.
    • Starting from the SD Memory Card hole, start prying between the top and bottom cases.
    • Use plastic tools to avoid damaging the cover.
    • Remove the bottom case.
  4. Acer Aspire V5-572, V5-572G HDD Replacement: adım 4, 1 resimden 1.
    • Disconnect the battery immediately for a safer repair.
    • Pull the battery connector away from the hard drive to disconnect it.
  5. Acer Aspire V5-572, V5-572G HDD Replacement, HDD: adım 5, 3 resimden 1. Acer Aspire V5-572, V5-572G HDD Replacement, HDD: adım 5, 3 resimden 2. Acer Aspire V5-572, V5-572G HDD Replacement, HDD: adım 5, 3 resimden 3.
    • Disconnect the SATA Cable from the Mother Board.
    • Take out the HDD and remove the SATA cable from it.
    • Now you can change / upgrade your HDD.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
ZFix
194.120 İtibar
330 adet Kılavuz yazıldı
Ekip
Master Techs Master Techs üyesi
Community
327 Üyeler
1.700 adet Kılavuz yazıldı
7 Yorum
Thank you very much for the tutorial, it was a 12 minute job ☺️And extremely pleased with the new ssd its incredible
Best Regards
Luckystyx - Yanıt
Thank you so much for the extremely easy tutorial and it definitely only took 2 minutes longer (12 minutes)
Your site is invaluable, Keep up the great work and all that you do,
5 star rating for you guys..
Kindest Regards
@Styx
Luckystyx - Yanıt
So the original hdd came in with the win 7 and it was later upgraded to win 10 for free. If i change it to ssd would i be able to get on it my original copy of win 7 and will it upgrade to win 10?
ashmir - Yanıt
ashmir, you just clone your HDD with a free software such as Macrium Reflect and don’t need to worry about installing everything from zero!!!
Miguel Rodríguez - Yanıt
Thank you for the tutorial.
But need a clarification. If i have a faulty hard disc it starts up but it freezes after 20 minutes.
Is it still possible to clone it.
Also if i change the hard drive do I need to install any software or the bios all over again.
Your inputs will be appreciated.
olatunji.jimoh - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 12
Son 30 gün: 91
Her zaman: 18,665
