Ana içeriğe geç
Acer Aspire V5-572, V5-572G HDD Replacement
Neye ihtiyacın var
Videoya Genel Bakış
  1. Acer Aspire V5-572, V5-572G HDD Replacement, Bottom Cover: adım 1, 1 resimden 1.
    • Switch-off the Laptop.
    • Remove the seventeen Philips #0 screws.
  2. Acer Aspire V5-572, V5-572G HDD Replacement: adım 2, 1 resimden 1.
    • If there is a plastic storage tray in the laptop, remove it.
  3. Acer Aspire V5-572, V5-572G HDD Replacement: adım 3, 3 resimden 1. Acer Aspire V5-572, V5-572G HDD Replacement: adım 3, 3 resimden 2. Acer Aspire V5-572, V5-572G HDD Replacement: adım 3, 3 resimden 3.
    • Starting from the SD Memory Card hole, start prying between the top and bottom cases.
    • Use plastic tools to avoid damaging the cover.
    • Remove the bottom case.
    Love the tutorial man...but this is the most moronic thing I've ever seen...you can take batery out of laptop 15 years old in a flash, while here you have to disassemble the whole %#*@ laptop...only idiots can come up with something like that
    razbojnikkuro - Yanıt
    I have to agree that this is extremely complicated and intense.
    There is no way your average user should be doing this and the average user should be able to replace the battery!!
    Like everything in the computer world, hardware or software, ease of use is no longer even a consideration!!
    Technical Support Bots are the rule and they rarely are up to date with the pages on the website!!
    Sucks!!
    andy.cox - Yanıt
  4. Acer Aspire V5-572, V5-572G HDD Replacement: adım 4, 1 resimden 1.
    • Disconnect the battery immediately for a safer repair.
    • Pull the battery connector away from the hard drive to disconnect it.
  5. Acer Aspire V5-572, V5-572G HDD Replacement, HDD: adım 5, 3 resimden 1. Acer Aspire V5-572, V5-572G HDD Replacement, HDD: adım 5, 3 resimden 2. Acer Aspire V5-572, V5-572G HDD Replacement, HDD: adım 5, 3 resimden 3.
    • Disconnect the SATA Cable from the Mother Board.
    • Take out the HDD and remove the SATA cable from it.
    • Now you can change / upgrade your HDD.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
ZFix
194.171 İtibar
330 adet Kılavuz yazıldı
Ekip
Master Techs Master Techs üyesi
Community
326 Üyeler
1.672 adet Kılavuz yazıldı
7Kılavuz Yorumları
Thank you very much for the tutorial, it was a 12 minute job ☺️And extremely pleased with the new ssd its incredible
Best Regards
Luckystyx - Yanıt
Thank you so much for the extremely easy tutorial and it definitely only took 2 minutes longer (12 minutes)
Your site is invaluable, Keep up the great work and all that you do,
5 star rating for you guys..
Kindest Regards
@Styx
Luckystyx - Yanıt
So the original hdd came in with the win 7 and it was later upgraded to win 10 for free. If i change it to ssd would i be able to get on it my original copy of win 7 and will it upgrade to win 10?
ashmir - Yanıt
ashmir, you just clone your HDD with a free software such as Macrium Reflect and don’t need to worry about installing everything from zero!!!
Miguel Rodríguez - Yanıt
Thank you for the tutorial.
But need a clarification. If i have a faulty hard disc it starts up but it freezes after 20 minutes.
Is it still possible to clone it.
Also if i change the hard drive do I need to install any software or the bios all over again.
Your inputs will be appreciated.
olatunji.jimoh - Yanıt
I haven’t had much luck cloning hard drives that already showed signs of failure, but it costs nothing to try. Download something like Macrium Reflect (free version) and plug the new drive into an external enclosure, and see if it will clone successfully.
Jeff Suovanen -
Can i add ssd and keep my hard drive?
Please somebody answer my question!
Saeid Heydari - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 14
Son 30 gün: 87
Her zaman: 18,678
