Ana içeriğe geç
Acer Chromebook 11 C733 Battery Replacement
Neye ihtiyacın var
  1. Acer Chromebook 11 C733 Battery Replacement, Opening up your device: adım 1, 2 resimden 1. Acer Chromebook 11 C733 Battery Replacement, Opening up your device: adım 1, 2 resimden 2.
    • Flip the computer over, and using a Phillips #1 screwdriver, remove all 12 bottom cover screws.
    • Once all the screws are removed, place both pointer fingers between the screen hinges and the case and carefully pry the case away from the hinges.
  2. Acer Chromebook 11 C733 Battery Replacement, Remove the ESD tape: adım 2, 3 resimden 1. Acer Chromebook 11 C733 Battery Replacement, Remove the ESD tape: adım 2, 3 resimden 2. Acer Chromebook 11 C733 Battery Replacement, Remove the ESD tape: adım 2, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Once the back cover is removed, you will see that the battery is only held in place with a few pieces of ESD Tape. Using a set of tweezers, or your fingers, carefully peel away the tape from one end.
    • You might need to peel away the tape covering the keyboard cable.
  3. Acer Chromebook 11 C733 Battery Replacement, Disconnect your battery: adım 3, 1 resimden 1.
    • Once the tape is removed, you can use the pointed end of a Spudger or your fingernails and carefully unplug the battery from the logic board.
    • The battery can now be removed.
    • To install the new battery, follow these steps in reverse order.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Jacob Mehnert
38.708 İtibar
50 adet Kılavuz yazıldı
Ekip
iFanatics iFanatics üyesi
Community
61 Üyeler
192 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 17
Son 30 gün: 36
Her zaman: 1,154
