Ana içeriğe geç
Acer Chromebook 14 CB3-431-C3WS Battery Replacement
Neye ihtiyacın var
  1. Acer Chromebook 14 CB3-431-C3WS Battery Replacement, Back Cover: adım 1, 3 resimden 1. Acer Chromebook 14 CB3-431-C3WS Battery Replacement, Back Cover: adım 1, 3 resimden 2. Acer Chromebook 14 CB3-431-C3WS Battery Replacement, Back Cover: adım 1, 3 resimden 3.
    • Remove the two 6mm JIS #0 screws from either side of the hinges.
  2. Acer Chromebook 14 CB3-431-C3WS Battery Replacement: adım 2, 1 resimden 1.
    • Remove the eight 4mm JIS #0 screws from the back cover.
  3. Acer Chromebook 14 CB3-431-C3WS Battery Replacement: adım 3, 2 resimden 1. Acer Chromebook 14 CB3-431-C3WS Battery Replacement: adım 3, 2 resimden 2.
    • Insert an opening pick between the back panel and the sides of the computer to begin lifting the back off.
    • There are several clips holding the cover in place.
    • After the sides have been lifted, use the opening tool to finish opening the back cover.
  4. Acer Chromebook 14 CB3-431-C3WS Battery Replacement: adım 4, 1 resimden 1.
    • Lift off the back cover.
  5. Acer Chromebook 14 CB3-431-C3WS Battery Replacement, Battery: adım 5, 3 resimden 1. Acer Chromebook 14 CB3-431-C3WS Battery Replacement, Battery: adım 5, 3 resimden 2. Acer Chromebook 14 CB3-431-C3WS Battery Replacement, Battery: adım 5, 3 resimden 3.
    • Remove the two JIS #0 screws that connect the battery to the rest of the laptop.
  6. Acer Chromebook 14 CB3-431-C3WS Battery Replacement: adım 6, 2 resimden 1. Acer Chromebook 14 CB3-431-C3WS Battery Replacement: adım 6, 2 resimden 2.
    • Pull the white tab connected to the battery out of the black tab that connects to the motherboard.
    • It is extremely important that this is done carefully and slowly to avoid causing damage to the motherboard.
  7. Acer Chromebook 14 CB3-431-C3WS Battery Replacement: adım 7, 1 resimden 1.
    • Lift the battery out gently.
Sonuç
8 farklı kişi bu kılavuzu tamamladı.
3 Yorum
Bonjour vous vendez les batteries CB3-431
mercier-nicolas - Yanıt
Vous vendez les batteries CB3-431
Instructions were great. Battery installation complete! I was very glad to find step by step instructions instead of a video. The Chromebook powered up successfully. Now waiting for it to charge. Thank you!
Sherry Chase - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 21
Her zaman: 5,688
