Ana içeriğe geç
Acer Chromebook 14 CB3-431-C3WS Motherboard Replacement
Neye ihtiyacın var
  1. Acer Chromebook 14 CB3-431-C3WS Motherboard Replacement, Back Cover: adım 1, 3 resimden 1. Acer Chromebook 14 CB3-431-C3WS Motherboard Replacement, Back Cover: adım 1, 3 resimden 2. Acer Chromebook 14 CB3-431-C3WS Motherboard Replacement, Back Cover: adım 1, 3 resimden 3.
    • Remove the two 6mm JIS #0 screws from either side of the hinges.
  2. Acer Chromebook 14 CB3-431-C3WS Motherboard Replacement: adım 2, 1 resimden 1.
    • Remove the eight 4mm JIS #0 screws from the back cover.
  3. Acer Chromebook 14 CB3-431-C3WS Motherboard Replacement: adım 3, 2 resimden 1. Acer Chromebook 14 CB3-431-C3WS Motherboard Replacement: adım 3, 2 resimden 2.
    • Insert an opening pick between the back panel and the sides of the computer to begin lifting the back off.
    • There are several clips holding the cover in place.
    • After the sides have been lifted, use the opening tool to finish opening the back cover.
  4. Acer Chromebook 14 CB3-431-C3WS Motherboard Replacement: adım 4, 1 resimden 1.
    • Lift off the back cover.
  5. Acer Chromebook 14 CB3-431-C3WS Motherboard Replacement, Battery: adım 5, 3 resimden 1. Acer Chromebook 14 CB3-431-C3WS Motherboard Replacement, Battery: adım 5, 3 resimden 2. Acer Chromebook 14 CB3-431-C3WS Motherboard Replacement, Battery: adım 5, 3 resimden 3.
    • Remove the two JIS #0 screws that connect the battery to the rest of the laptop.
  6. Acer Chromebook 14 CB3-431-C3WS Motherboard Replacement: adım 6, 2 resimden 1. Acer Chromebook 14 CB3-431-C3WS Motherboard Replacement: adım 6, 2 resimden 2.
    • Pull the white tab connected to the battery out of the black tab that connects to the motherboard.
    • It is extremely important that this is done carefully and slowly to avoid causing damage to the motherboard.
  7. Acer Chromebook 14 CB3-431-C3WS Motherboard Replacement: adım 7, 1 resimden 1.
    • Lift the battery out gently.
  8. Acer Chromebook 14 CB3-431-C3WS Motherboard Replacement, Motherboard: adım 8, 1 resimden 1.
    • Disconnect the LCD cable from the motherboard by removing the tape on the LCD connector, then gently pulling out the ribbon cable.
  9. Acer Chromebook 14 CB3-431-C3WS Motherboard Replacement: adım 9, 3 resimden 1. Acer Chromebook 14 CB3-431-C3WS Motherboard Replacement: adım 9, 3 resimden 2. Acer Chromebook 14 CB3-431-C3WS Motherboard Replacement: adım 9, 3 resimden 3.
    • Disconnect the LCD cable from the motherboard by gently pulling on the cable.
  10. Acer Chromebook 14 CB3-431-C3WS Motherboard Replacement: adım 10, 1 resimden 1.
    • Disconnect the trackpad by pulling on the trackpad connector cable.
  11. Acer Chromebook 14 CB3-431-C3WS Motherboard Replacement: adım 11, 2 resimden 1. Acer Chromebook 14 CB3-431-C3WS Motherboard Replacement: adım 11, 2 resimden 2.
    • Disconnect the daughterboard from the motherboard by gently removing the daughterboard cable from the motherboard connector.
  12. Acer Chromebook 14 CB3-431-C3WS Motherboard Replacement: adım 12, 2 resimden 1. Acer Chromebook 14 CB3-431-C3WS Motherboard Replacement: adım 12, 2 resimden 2.
    • Remove the electrical tape covering the screw that holds the Wi-Fi card in place.
    • Remove the single 4mm JIS #0 screw that holds the Wi-Fi card in place.
  13. Acer Chromebook 14 CB3-431-C3WS Motherboard Replacement: adım 13, 1 resimden 1.
    • Remove the seven 4mm JIS #0 screws that hold the motherboard in place.
  14. Acer Chromebook 14 CB3-431-C3WS Motherboard Replacement: adım 14, 1 resimden 1.
    • Gently remove the motherboard.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 11
Son 30 gün: 42
Her zaman: 1,905
