Ana içeriğe geç
Acer Chromebook 14 CB3-431-C3WS Screen Replacement
Neye ihtiyacın var
  1. Acer Chromebook 14 CB3-431-C3WS Screen Replacement, Screen: adım 1, 2 resimden 1. Acer Chromebook 14 CB3-431-C3WS Screen Replacement, Screen: adım 1, 2 resimden 2.
    • Using an iFixit opening pick, pop off the bezel from around the screen, beginning on one side and continuing around the whole screen.
    • Remove the barrier from the front of the screen.
  2. Acer Chromebook 14 CB3-431-C3WS Screen Replacement: adım 2, 1 resimden 1.
    • Starting in the top right of the screen, remove the six 4mm JIS #0 screws that secure the computer screen to the top.
    • There will be two sets of two screws on the top, one screw on each side of the bottom of the screen.
  3. Acer Chromebook 14 CB3-431-C3WS Screen Replacement: adım 3, 1 resimden 1.
    • Pull the screen down, and lay it flat against the keyboard.
  4. Acer Chromebook 14 CB3-431-C3WS Screen Replacement: adım 4, 1 resimden 1.
    • Disconnect the input connector from the screen.
  5. Acer Chromebook 14 CB3-431-C3WS Screen Replacement: adım 5, 1 resimden 1.
    • Remove the screen.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
3 Yorum
I have horizontal lines that appear for a split second on my screen at random times . Pushing the screen makes the lines appear also. I think I might have dropped my laptop , which may have caused this. Would changing the screen fix this?
aarondhesi - Yanıt
Hi, i have the same problem. did it work for you?
Another Backup -
It should! When we looked into troubleshooting this, changing the screen can help with the lines you're seeing.
Samantha Postma - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 21
Her zaman: 3,404
