Ana içeriğe geç
Acer Chromebook 15 CB5-571-C09S Fan Replacement
Neye ihtiyacın var
  1. Acer Chromebook 15 CB5-571-C09S Fan Replacement, Back Cover: adım 1, 1 resimden 1.
    • Place the device on a flat surface faced down so that the fan vents are at the top of the device.
  2. Acer Chromebook 15 CB5-571-C09S Fan Replacement: adım 2, 2 resimden 1. Acer Chromebook 15 CB5-571-C09S Fan Replacement: adım 2, 2 resimden 2.
    • Unscrew the eighteen 6 mm PH0 Phillips head screws from the back of the device.
  3. Acer Chromebook 15 CB5-571-C09S Fan Replacement: adım 3, 2 resimden 1. Acer Chromebook 15 CB5-571-C09S Fan Replacement: adım 3, 2 resimden 2.
    • Use a plastic opening tool to pry open the back cover around the edges of the device.
    • Be careful not to crack or break the back cover of the device.
    • You will have to adjust the position of the device to pry it open along all the edges.
  4. Acer Chromebook 15 CB5-571-C09S Fan Replacement: adım 4, 2 resimden 1. Acer Chromebook 15 CB5-571-C09S Fan Replacement: adım 4, 2 resimden 2.
    • Stand the device up with the hinges on top and carefully pull apart the back cover from the device.
  5. Acer Chromebook 15 CB5-571-C09S Fan Replacement, Fan: adım 5, 3 resimden 1. Acer Chromebook 15 CB5-571-C09S Fan Replacement, Fan: adım 5, 3 resimden 2. Acer Chromebook 15 CB5-571-C09S Fan Replacement, Fan: adım 5, 3 resimden 3.
    • The fan is located at the top of the device enclosed by a grey plastic covering and is attached to the motherboard by a piece of brass colored metal.
    • Unscrew the four 3 mm PH00 Phillips screws located on the corner edges of the brass colored piece of metal.
  6. Acer Chromebook 15 CB5-571-C09S Fan Replacement: adım 6, 2 resimden 1. Acer Chromebook 15 CB5-571-C09S Fan Replacement: adım 6, 2 resimden 2.
    • Unscrew the two 4 mm PH00 Phillips head screws on either side of the the fan.
    • Be aware that these screw are enclosed by small pieces of plastic and are not to be removed from the fan cover.
  7. Acer Chromebook 15 CB5-571-C09S Fan Replacement: adım 7, 2 resimden 1. Acer Chromebook 15 CB5-571-C09S Fan Replacement: adım 7, 2 resimden 2.
    • Disconnect the fan connector from the motherboard using two plastic opening tools.
    • The fan connector is the white "plug" that connects the battery to the motherboard with yellow, white, red and black wires attached to it.
  8. Acer Chromebook 15 CB5-571-C09S Fan Replacement: adım 8, 2 resimden 1. Acer Chromebook 15 CB5-571-C09S Fan Replacement: adım 8, 2 resimden 2.
    • Carefully unwrap the black and white wires from around the fan cover.
    • Be careful not to remove the wires from the Intel Dual Band Wireless-AC 7260 ports located just beneath the fan connector.
  9. Acer Chromebook 15 CB5-571-C09S Fan Replacement: adım 9, 1 resimden 1.
    • Grab the fan by its cover and the brass colored piece of metal and carefully lift up and pull out the fan from the device.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Sakiynah Howard
1.000 İtibar
6 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S1-G3, Simcock Fall 2017 UMass Dartmouth, Team S1-G3, Simcock Fall 2017 üyesi
UMASSD-SIMCOCK-F17S1G3
3 Üyeler
12 adet Kılavuz yazıldı
Bir Yorum
Thanks for the guide. I was able to successfully replace my fan using it. I would like to point out a couple of things:
1. 10 minutes is not a realistic completion time for this guide.
2. Disconnecting the fan plug is challenging. It might have been easier with a small pair of pliers.
3. Since this guide involves dis/re-connecting the thermal interface between the processor and heat sink, you should be prepared to properly clean both surfaces and re-apply new thermal compound. There is an excellent guide on applying thermal compound here:
How to Apply Thermal Paste
Tristan Mackey - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 12
Her zaman: 366
