Ana içeriğe geç
Acer Chromebook C720-2844 Battery Replacement
Neye ihtiyacın var
  1. Acer Chromebook C720-2844 Battery Replacement, Battery: adım 1, 3 resimden 1. Acer Chromebook C720-2844 Battery Replacement, Battery: adım 1, 3 resimden 2. Acer Chromebook C720-2844 Battery Replacement, Battery: adım 1, 3 resimden 3.
    • Flip to the back cover of the laptop.
    • Remove the 1 cm Phillips #00 screws on the back cover.
    • Use pry tools to remove the back cover.
  2. Acer Chromebook C720-2844 Battery Replacement: adım 2, 1 resimden 1.
    • Take out your Phillips #00 screwdriver.
    • Remove the 1 cm screws of the battery. There are two of screws, one is on the left of the battery and the other is on the right. (circled in red).
  3. Acer Chromebook C720-2844 Battery Replacement: adım 3, 2 resimden 1. Acer Chromebook C720-2844 Battery Replacement: adım 3, 2 resimden 2.
    • Unplug the battery from the motherboard by pulling the bundled cable connector free.
    • Lift the top part of battery.
    • Slide the battery forward to remove it completely from the motherboard.
Sonuç
Fabian Sanchez
247 İtibar
1 Kılavuz yazıldı
Ekip
Gateway, Team 1-2, Pee Spring 2022 Gateway, Team 1-2, Pee Spring 2022 üyesi
GCC-PEE-S22S1G2
4 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 13
Her zaman: 194
