Ana içeriğe geç
Acer Chromebook C731-C8VE Keyboard Replacement
Neye ihtiyacın var
  1. Acer Chromebook C731-C8VE Keyboard Replacement, Battery: adım 1, 1 resimden 1.
    • Place the Chromebook face down.
  2. Acer Chromebook C731-C8VE Keyboard Replacement: adım 2, 1 resimden 1.
    • Make sure to completely turn off the device before beginning this step.
    • Use a JIS #00 screwdriver to remove the 11 screws on the underside of the laptop.
    • These 2 mm screws have washers and will be located on the left and right of the device.
    • The 2 mm screws marked orange do not have washers attached and must be placed in these specific areas.
  3. Acer Chromebook C731-C8VE Keyboard Replacement: adım 3, 2 resimden 1. Acer Chromebook C731-C8VE Keyboard Replacement: adım 3, 2 resimden 2.
    • Use the iFixit opening tool to remove the keyboard from the device by prying it loose from the base.
  4. Acer Chromebook C731-C8VE Keyboard Replacement: adım 4, 3 resimden 1. Acer Chromebook C731-C8VE Keyboard Replacement: adım 4, 3 resimden 2. Acer Chromebook C731-C8VE Keyboard Replacement: adım 4, 3 resimden 3.
    • Detach the wires connecting the keyboard and the touchpad to the motherboard by lifting the black connectors up.
  5. Acer Chromebook C731-C8VE Keyboard Replacement: adım 5, 3 resimden 1. Acer Chromebook C731-C8VE Keyboard Replacement: adım 5, 3 resimden 2. Acer Chromebook C731-C8VE Keyboard Replacement: adım 5, 3 resimden 3.
    • Use the JIS #00 screwdriver to take out the 1mm screw that connects the battery to the base.
    • Detach the battery from the motherboard by lifting it up gently to avoid any damage to the motherboard.
  6. Acer Chromebook C731-C8VE Keyboard Replacement: adım 6, 1 resimden 1.
    • Remove the battery from the base of the device.
    • Do this step slowly to ensure that you do not damage the battery or the motherboard.
  7. Acer Chromebook C731-C8VE Keyboard Replacement, Keyboard: adım 7, 1 resimden 1.
    • Use the JIS #00 Screwdriver to remove the four 0.5 mm screws holding the trackpad in order to detach it from the keyboard.
  8. Acer Chromebook C731-C8VE Keyboard Replacement: adım 8, 2 resimden 1. Acer Chromebook C731-C8VE Keyboard Replacement: adım 8, 2 resimden 2.
    • Lift and remove the trackpad to isolate the keyboard.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Bir Yorum
Thank you for guide
UMAR RASHID - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 13
Her zaman: 171
