Ana içeriğe geç
Acer Chromebook C731-C8VE Keyboard Replacement
Sophia Medley
Sophia Medley ve 2 diğer katkıda bulunanlar
En son May 19, 2023 tarihinde güncellendi
25 dakika
Kolay
If the keyboard has stopped working for your Acer Chromebook ( model C731-C8VE) this guide will help you with all of the steps you need to take to replace the keyboard assembly.
A broken keyboard can result in certain keys not registering, or none of the keys registering at all. If this is the case, its important to make sure you replace the keyboard in order to get your Chromebook up and working like new again!
Before starting on this repair, you need to make sure that the power on the laptop is completely turned off, especially since we will be removing the battery for this replacement.
Neye ihtiyacın var
Aletler
  1. Acer Chromebook C731-C8VE Keyboard Replacement, Battery: adım 1, 1 resimden 1.
    • Place the Chromebook face down.
  2. Acer Chromebook C731-C8VE Keyboard Replacement: adım 2, 1 resimden 1.
    • Make sure to completely turn off the device before beginning this step.
    • Use a JIS #00 screwdriver to remove the 11 screws on the underside of the laptop.
    • These 2 mm screws have washers and will be located on the left and right of the device.
    • The 2 mm screws marked orange do not have washers attached and must be placed in these specific areas.
  3. Acer Chromebook C731-C8VE Keyboard Replacement: adım 3, 2 resimden 1. Acer Chromebook C731-C8VE Keyboard Replacement: adım 3, 2 resimden 2.
    • Use the iFixit opening tool to remove the keyboard from the device by prying it loose from the base.
  4. Acer Chromebook C731-C8VE Keyboard Replacement: adım 4, 3 resimden 1. Acer Chromebook C731-C8VE Keyboard Replacement: adım 4, 3 resimden 2. Acer Chromebook C731-C8VE Keyboard Replacement: adım 4, 3 resimden 3.
    • Detach the wires connecting the keyboard and the touchpad to the motherboard by lifting the black connectors up.
  5. Acer Chromebook C731-C8VE Keyboard Replacement: adım 5, 3 resimden 1. Acer Chromebook C731-C8VE Keyboard Replacement: adım 5, 3 resimden 2. Acer Chromebook C731-C8VE Keyboard Replacement: adım 5, 3 resimden 3.
    • Use the JIS #00 screwdriver to take out the 1mm screw that connects the battery to the base.
    • Detach the battery from the motherboard by lifting it up gently to avoid any damage to the motherboard.
  6. Acer Chromebook C731-C8VE Keyboard Replacement: adım 6, 1 resimden 1.
    • Remove the battery from the base of the device.
    • Do this step slowly to ensure that you do not damage the battery or the motherboard.
  7. Acer Chromebook C731-C8VE Keyboard Replacement, Keyboard: adım 7, 1 resimden 1.
    • Use the JIS #00 Screwdriver to remove the four 0.5 mm screws holding the trackpad in order to detach it from the keyboard.
  8. Acer Chromebook C731-C8VE Keyboard Replacement: adım 8, 2 resimden 1. Acer Chromebook C731-C8VE Keyboard Replacement: adım 8, 2 resimden 2.
    • Lift and remove the trackpad to isolate the keyboard.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Bir Yorum
Thank you for guide
UMAR RASHID - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 13
Her zaman: 172
