Ana içeriğe geç
Acer Chromebook CB3-111-C670 Battery Replacement
Neye ihtiyacın var
  1. Acer Chromebook CB3-111-C670 Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Be sure to have completely shut down the device before attempting to open it.
    • Remove the twelve Phillips #00 screws.
  2. Acer Chromebook CB3-111-C670 Battery Replacement: adım 2, 1 resimden 1.
    • Insert a prying tool in between the top and bottom pieces of the laptop case to pry them apart but *do not remove the lower case*.
    • Carefully open the case to the left to avoid ripping the interior ribbon cable.
  3. Acer Chromebook CB3-111-C670 Battery Replacement: adım 3, 1 resimden 1.
    • Pull the battery connector cable towards the battery to disconnect it.
  4. Acer Chromebook CB3-111-C670 Battery Replacement: adım 4, 1 resimden 1.
    • Remove the battery.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Tony
459 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 10-5, Remmell Spring 2016 USF Tampa, Team 10-5, Remmell Spring 2016 üyesi
USFT-REMMELL-S16S10G5
3 Üyeler
8 adet Kılavuz yazıldı
Bir Yorum
Off topic and everything but how can i fix the audio jack? My audio jack is so worn it wont play sound
Daichi Potato - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 13
Her zaman: 4,075
