Ana içeriğe geç
Acer Chromebook CB3-532-C47C Motherboard Replacement
Neye ihtiyacın var
  1. Acer Chromebook CB3-532-C47C Motherboard Replacement, Back Panel: adım 1, 2 resimden 1. Acer Chromebook CB3-532-C47C Motherboard Replacement, Back Panel: adım 1, 2 resimden 2.
    • Power off the laptop before beginning the replacement.
    • Using the Phillips #1 screwdriver, remove eighteen 7 mm screws from the back panel of the device.
  2. Acer Chromebook CB3-532-C47C Motherboard Replacement: adım 2, 2 resimden 1. Acer Chromebook CB3-532-C47C Motherboard Replacement: adım 2, 2 resimden 2.
    • Use a plastic opening tool around the edges of the laptop and remove the back panel from the device.
  3. Acer Chromebook CB3-532-C47C Motherboard Replacement, Remove the battery cable: adım 3, 1 resimden 1.
    • Push on the sides of the connector with a plastic spudger to separate the cable from the motherboard.
  4. Acer Chromebook CB3-532-C47C Motherboard Replacement, Unplug the WiFi Antenna Connectors: adım 4, 2 resimden 1. Acer Chromebook CB3-532-C47C Motherboard Replacement, Unplug the WiFi Antenna Connectors: adım 4, 2 resimden 2.
    • Firmly pull the end of the black wire attached to the Wi-Fi card upwards and remove it from the device.
    • Repeat with the white wire.
  5. Acer Chromebook CB3-532-C47C Motherboard Replacement, WiFi Card: adım 5, 3 resimden 1. Acer Chromebook CB3-532-C47C Motherboard Replacement, WiFi Card: adım 5, 3 resimden 2. Acer Chromebook CB3-532-C47C Motherboard Replacement, WiFi Card: adım 5, 3 resimden 3.
    • Using the Phillips #0 screwdriver, remove the single 6 mm screw securing the Wi-Fi card.
    • Pull the Wi-Fi card straight out of the motherboard and remove it from the device.
  6. Acer Chromebook CB3-532-C47C Motherboard Replacement, Disconnect the Speakers: adım 6, 2 resimden 1. Acer Chromebook CB3-532-C47C Motherboard Replacement, Disconnect the Speakers: adım 6, 2 resimden 2.
    • Pull the black ribbon attached to the speakers out of the motherboard.
  7. Acer Chromebook CB3-532-C47C Motherboard Replacement, Keyboard Cable: adım 7, 3 resimden 1. Acer Chromebook CB3-532-C47C Motherboard Replacement, Keyboard Cable: adım 7, 3 resimden 2. Acer Chromebook CB3-532-C47C Motherboard Replacement, Keyboard Cable: adım 7, 3 resimden 3.
    • Peel the yellow tape off the black keyboard ribbon cable on the motherboard.
    • Use a spudger to slide the black tabs on either side of the connector forward slightly.
    • Pull the black ribbon straight towards you to remove it from the motherboard.
  8. Acer Chromebook CB3-532-C47C Motherboard Replacement: adım 8, 3 resimden 1. Acer Chromebook CB3-532-C47C Motherboard Replacement: adım 8, 3 resimden 2. Acer Chromebook CB3-532-C47C Motherboard Replacement: adım 8, 3 resimden 3.
    • Flip up the tabs over the two white ribbons on the left using your finger.
    • For more information on Zero Insertion Force (ZIF) connectors, please visit this guide.
    • Pull the ribbons out of the motherboard by the blue tabs.
  9. Acer Chromebook CB3-532-C47C Motherboard Replacement: adım 9, 1 resimden 1.
    • Using the Phillips #1 screwdriver, remove four 6 mm screws.
    • Using the same Phillips #1 screwdriver, remove five 3 mm screws securing the metal plate to the motherboard.
  10. Acer Chromebook CB3-532-C47C Motherboard Replacement, Remove Motherboard: adım 10, 1 resimden 1.
    • Remove the metal plate over the motherboard.
    • Remove the motherboard.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Sadie Brown
967 İtibar
7 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 3-2, Sinclaire Fall 2021 UMass Dartmouth, Team 3-2, Sinclaire Fall 2021 üyesi
UMASSD-SINCLAIRE-F21S3G2
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 7
Son 30 gün: 20
Her zaman: 631
