Ana içeriğe geç
Acer Chromebook CB3-532-C47C Touchpad Replacement
Neye ihtiyacın var
  1. Acer Chromebook CB3-532-C47C Touchpad Replacement, Back Panel: adım 1, 2 resimden 1. Acer Chromebook CB3-532-C47C Touchpad Replacement, Back Panel: adım 1, 2 resimden 2.
    • Power off the laptop before beginning the replacement.
    • Using the Phillips #1 screwdriver, remove eighteen 7 mm screws from the back panel of the device.
  2. Acer Chromebook CB3-532-C47C Touchpad Replacement: adım 2, 2 resimden 1. Acer Chromebook CB3-532-C47C Touchpad Replacement: adım 2, 2 resimden 2.
    • Use a plastic opening tool around the edges of the laptop and remove the back panel from the device.
  3. Acer Chromebook CB3-532-C47C Touchpad Replacement, Remove the battery cable: adım 3, 1 resimden 1.
    • Push on the sides of the connector with a plastic spudger to separate the cable from the motherboard.
  4. Acer Chromebook CB3-532-C47C Touchpad Replacement, Battery: adım 4, 2 resimden 1. Acer Chromebook CB3-532-C47C Touchpad Replacement, Battery: adım 4, 2 resimden 2.
    • Using the Phillips #1 screwdriver, remove the two black 5.5 mm screws securing the battery.
  5. Acer Chromebook CB3-532-C47C Touchpad Replacement: adım 5, 1 resimden 1.
    • Remove the battery from the laptop.
  6. Acer Chromebook CB3-532-C47C Touchpad Replacement, Touchpad: adım 6, 2 resimden 1. Acer Chromebook CB3-532-C47C Touchpad Replacement, Touchpad: adım 6, 2 resimden 2.
    • Flip up the retaining latch securing the touchpad cable to the motherboard.
  7. Acer Chromebook CB3-532-C47C Touchpad Replacement: adım 7, 1 resimden 1.
    • Pull the ribbon from the motherboard laterally off the touchpad.
  8. Acer Chromebook CB3-532-C47C Touchpad Replacement: adım 8, 1 resimden 1.
    • Using the Phillips #1 screwdriver, remove the three 3.2 mm screws holding the touchpad to the laptop.
  9. Acer Chromebook CB3-532-C47C Touchpad Replacement: adım 9, 3 resimden 1. Acer Chromebook CB3-532-C47C Touchpad Replacement: adım 9, 3 resimden 2. Acer Chromebook CB3-532-C47C Touchpad Replacement: adım 9, 3 resimden 3.
    • Carefully lift up on the keyboard ribbon cable and the insulating sheet immediately below it so the touchpad can clear them.
    • Lift the touchpad slightly from the top.
    • Pull the touchpad toward the motherboard as you continue to lift it, sliding it out from under the retaining fingers at the bottom.
  10. Acer Chromebook CB3-532-C47C Touchpad Replacement: adım 10, 3 resimden 1. Acer Chromebook CB3-532-C47C Touchpad Replacement: adım 10, 3 resimden 2. Acer Chromebook CB3-532-C47C Touchpad Replacement: adım 10, 3 resimden 3.
    • Remove the touchpad.
    • When reinstalling:
    • Make sure the touchpad goes underneath the two retaining fingers when reinstalling it.
    • The touchpad is correctly aligned when the guide pins next to the left and right screws are inserted in the holes.
Sonuç
Sadie Brown
967 İtibar
7 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 3-2, Sinclaire Fall 2021 UMass Dartmouth, Team 3-2, Sinclaire Fall 2021 üyesi
UMASSD-SINCLAIRE-F21S3G2
3 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 25
Her zaman: 294
