Acer Chromebook CP5-471-C0EX Trackpad Replacement
Giriş
1. adıma gitThis guide will show you how to replace the trackpad (or touchpad) on your Acer Chromebook CP5-471-C0EX laptop. If your touchpad isn't working, it may be a result of a missing or out-of-date driver or a build-up of dirt and dust over time. The replacement of the trackpad may solve issues with unresponsiveness.
Make sure to power down your device and disconnect from any power sources before you begin.
Neye ihtiyacın var
Carefully detach the ribbon cable connecting the battery and the motherboard.
Disconnect the wide black ribbon cable from the motherboard using an iFixit opening tool.
Disconnect the blue-tipped ribbon from the motherboard.
Bir başkası bu kılavuzu tamamladı.
