Ana içeriğe geç
AcuRite 02081M Observer Repair Battery,LCD Screen,Push Button Replacement
anhut51190
anhut51190 ve 4 diğer katkıda bulunanlar
En son July 26, 2024 tarihinde güncellendi
Tahmin yok
Orta
Topluluk-Katkılı Kılavuz
The console itself has dual levels of connectivity – the sensor uses RF (915 Mhz) while the console connects directly to your router (2.4 GHz).
  1. AcuRite 02081M Observer Repair Battery,LCD Screen,Push Button Replacement, Battery Replacement: adım 1, 1 resimden 1.
    • First, unscrew the 4 M2x1.5-7 screws (7mm length) from the back of the device using a number 1 Phillips screwdriver.
    • Pry the front silver panel away from the back black panel with a plastic opening tool.
  2. AcuRite 02081M Observer Repair Battery,LCD Screen,Push Button Replacement, Step 2: adım 2, 1 resimden 1.
    • Next, the ribbon cable needs to be carefully removed from the back of the LCD screen.
    • Use a plastic opening tool to press the black bar towards the ribbon and away from the white bar gently. This will release the ribbon.
  3. AcuRite 02081M Observer Repair Battery,LCD Screen,Push Button Replacement, step 3: adım 3, 1 resimden 1.
    • Remove the 4 M2x1.5-7 screws (7mm length) from the green PCB board.
    • This will result in two pieces, the back black cover and the PCB board.
  4. AcuRite 02081M Observer Repair Battery,LCD Screen,Push Button Replacement: adım 4, 1 resimden 1.
    Bu adımda kullanılan alet:
    • The battery can then be popped out using precision tweezers and replaced with a new one.
Sonuç
anhut51190
257 İtibar
2 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 22
Her zaman: 127
