Ana içeriğe geç
Adjust Goose-neck (adjustable quill stem) on Specialized Expedition
Neye ihtiyacın var
  1. Adjust Goose-neck (adjustable quill stem) on Specialized Expedition, Adjust Goose-neck (adjustable quill stem) on Specialized Expedition: adım 1, 2 resimden 1. Adjust Goose-neck (adjustable quill stem) on Specialized Expedition, Adjust Goose-neck (adjustable quill stem) on Specialized Expedition: adım 1, 2 resimden 2.
    • Remove the bolt cover with a flathead screwdriver.
  2. Adjust Goose-neck (adjustable quill stem) on Specialized Expedition: adım 2, 3 resimden 1. Adjust Goose-neck (adjustable quill stem) on Specialized Expedition: adım 2, 3 resimden 2. Adjust Goose-neck (adjustable quill stem) on Specialized Expedition: adım 2, 3 resimden 3.
    • Loosen the goose-neck (adjustable quill stem) with a 6 mm Allen wrench.
    • After loosening the goose-neck (adjustable quill stem), it still may be stiff. Hold the wheel from turning and twist the handlebars from side to side.
    • If quill stem is still stuck then place 6 mm Allen wrench firmly into bolt and tap with a mallet.
    • Position the handlebars to your preferred height. Make sure not to pull cable and housing to tight. I could adversely effect shifting and braking performance.
    • Make sure you don't raise quill stem above minimum insert line.
  3. Adjust Goose-neck (adjustable quill stem) on Specialized Expedition: adım 3, 3 resimden 1. Adjust Goose-neck (adjustable quill stem) on Specialized Expedition: adım 3, 3 resimden 2. Adjust Goose-neck (adjustable quill stem) on Specialized Expedition: adım 3, 3 resimden 3.
    • Align the direction of the goose-neck (adjustable quill stem) with the front tire.
    • Firmly tighten the goose-neck (adjustable quill stem) bolt using a 6 mm Allen wrench.
    • Pop the bolt cover back on.
    • If calling a bicycle repair shop, refer to it as a adjustable quill stem (technical term) instead of goose-neck as mechanic may not know what you are talking about.
Bitiş Çizgisi
Bir başkası bu kılavuzu tamamladı.
aaron thielk
1.882 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 5-13, Maness Fall 2010 Cal Poly, Team 5-13, Maness Fall 2010 üyesi
CPSU-MANESS-F10S5G13
4 Üyeler
17 adet Kılavuz yazıldı
Bir Yorum
Anyone know where/how to buy a replacement bolt cover?
Bennett Hart - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 11
Her zaman: 9,222
