Ana içeriğe geç
Adjust Goose-neck (adjustable quill stem) on Specialized Expedition
aaron thielk
aaron thielk ve 5 diğer katkıda bulunanlar
En son February 19, 2016 tarihinde güncellendi
5 - 10 dakika
Kolay
This guide will show you how to adjust the height of the handle bars and align the stem with the front wheel.
Neye ihtiyacın var
iFixit bu bağlantılar üzerinden satın aldığınızda komisyon kazanır.
  1. Adjust Goose-neck (adjustable quill stem) on Specialized Expedition, Adjust Goose-neck (adjustable quill stem) on Specialized Expedition: adım 1, 2 resimden 1. Adjust Goose-neck (adjustable quill stem) on Specialized Expedition, Adjust Goose-neck (adjustable quill stem) on Specialized Expedition: adım 1, 2 resimden 2.
    • Remove the bolt cover with a flathead screwdriver.
  2. Adjust Goose-neck (adjustable quill stem) on Specialized Expedition: adım 2, 3 resimden 1. Adjust Goose-neck (adjustable quill stem) on Specialized Expedition: adım 2, 3 resimden 2. Adjust Goose-neck (adjustable quill stem) on Specialized Expedition: adım 2, 3 resimden 3.
    • Loosen the goose-neck (adjustable quill stem) with a 6 mm Allen wrench.
    • After loosening the goose-neck (adjustable quill stem), it still may be stiff. Hold the wheel from turning and twist the handlebars from side to side.
    • If quill stem is still stuck then place 6 mm Allen wrench firmly into bolt and tap with a mallet.
    • Position the handlebars to your preferred height. Make sure not to pull cable and housing to tight. I could adversely effect shifting and braking performance.
    • Make sure you don't raise quill stem above minimum insert line.
  3. Adjust Goose-neck (adjustable quill stem) on Specialized Expedition: adım 3, 3 resimden 1. Adjust Goose-neck (adjustable quill stem) on Specialized Expedition: adım 3, 3 resimden 2. Adjust Goose-neck (adjustable quill stem) on Specialized Expedition: adım 3, 3 resimden 3.
    • Align the direction of the goose-neck (adjustable quill stem) with the front tire.
    • Firmly tighten the goose-neck (adjustable quill stem) bolt using a 6 mm Allen wrench.
    • Pop the bolt cover back on.
    • If calling a bicycle repair shop, refer to it as a adjustable quill stem (technical term) instead of goose-neck as mechanic may not know what you are talking about.
Bitiş Çizgisi
Bir başkası bu kılavuzu tamamladı.
aaron thielk
1.903 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 5-13, Maness Fall 2010 Cal Poly, Team 5-13, Maness Fall 2010 üyesi
CPSU-MANESS-F10S5G13
4 Üyeler
17 adet Kılavuz yazıldı
Bir Yorum
Anyone know where/how to buy a replacement bolt cover?
Bennett Hart - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 10
Son 30 gün: 21
Her zaman: 9,363
