Ana içeriğe geç
Afridev Axle and Handle Replacement
Neye ihtiyacın var
  1. Afridev Axle and Handle Replacement, Head: adım 1, 2 resimden 1. Afridev Axle and Handle Replacement, Head: adım 1, 2 resimden 2.
    • Assemble the required tools, including the Afridev tool and crescent wrenches.
  2. Afridev Axle and Handle Replacement: adım 2, 3 resimden 1. Afridev Axle and Handle Replacement: adım 2, 3 resimden 2. Afridev Axle and Handle Replacement: adım 2, 3 resimden 3.
    • Perform a water test on the pump, by raising and lowering the handle a full 40 strokes. A properly performing pump will yield greater than 10 liters.
  3. Afridev Axle and Handle Replacement: adım 3, 2 resimden 1. Afridev Axle and Handle Replacement: adım 3, 2 resimden 2.
    • Loosen the bolt on front of the face plate with the Afridev tool.
    • Remove the plate from the pump by lifting it straight up.
  4. Afridev Axle and Handle Replacement, Axle and Handle: adım 4, 3 resimden 1. Afridev Axle and Handle Replacement, Axle and Handle: adım 4, 3 resimden 2. Afridev Axle and Handle Replacement, Axle and Handle: adım 4, 3 resimden 3.
    • Insert the T-handle into the top cylinder of the exposed pump rod.
  5. Afridev Axle and Handle Replacement: adım 5, 2 resimden 1. Afridev Axle and Handle Replacement: adım 5, 2 resimden 2.
    • Loosen the 2 bolts on either side of handle.
    • It is not necessary to remove the bolt at this time; however, take caution to not let the bolt fall out of the handle.
  6. Afridev Axle and Handle Replacement: adım 6, 3 resimden 1. Afridev Axle and Handle Replacement: adım 6, 3 resimden 2. Afridev Axle and Handle Replacement: adım 6, 3 resimden 3.
    • Loosen the 2 bolts on either side of the head to remove the handle from the pump rod.
  7. Afridev Axle and Handle Replacement: adım 7, 2 resimden 1. Afridev Axle and Handle Replacement: adım 7, 2 resimden 2.
    • Lift the handle to a horizontal position.
  8. Afridev Axle and Handle Replacement: adım 8, 3 resimden 1. Afridev Axle and Handle Replacement: adım 8, 3 resimden 2. Afridev Axle and Handle Replacement: adım 8, 3 resimden 3.
    • While one person lifts up on the T-handle, remove the bolt and connection pieces.
  9. Afridev Axle and Handle Replacement: adım 9, 3 resimden 1. Afridev Axle and Handle Replacement: adım 9, 3 resimden 2. Afridev Axle and Handle Replacement: adım 9, 3 resimden 3.
    • Remove the bolt and connection pieces from the handle.
    • Set the bolt pieces in a sanitary place, such as a bucket, to prevent contamination.
  10. Afridev Axle and Handle Replacement: adım 10, 2 resimden 1. Afridev Axle and Handle Replacement: adım 10, 2 resimden 2.
    • Remove the handle from the pump.
    • Be sure to set the handle in a sanitary place to prevent contamination.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Jake Devincenzi
118.792 İtibar
57 adet Kılavuz yazıldı
2Kılavuz Yorumları
J'ai besoin de pompe
Sylvain Monga - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 14
Her zaman: 825
