Ana içeriğe geç
Afterglow Wireless PS3 Controller Motherboard Replacement
Neye ihtiyacın var
  1. Afterglow Wireless PS3 Controller Motherboard Replacement, Back Cover: adım 1, 2 resimden 1. Afterglow Wireless PS3 Controller Motherboard Replacement, Back Cover: adım 1, 2 resimden 2.
    • Lay the controller face down on a flat surface and remove the seven 9mm Phillips #0 screws on the back of the controller.
    • Lift up and remove the controller back plate.
  2. Afterglow Wireless PS3 Controller Motherboard Replacement, Motherboard: adım 2, 1 resimden 1.
    • Desolder the battery connection from the motherboard.
    • Use this guide for more information on soldering.
  3. Afterglow Wireless PS3 Controller Motherboard Replacement: adım 3, 2 resimden 1. Afterglow Wireless PS3 Controller Motherboard Replacement: adım 3, 2 resimden 2.
    • Unscrew the two 9mm Phillips #0 screws that secure the motherboard to the controller front plate.
  4. Afterglow Wireless PS3 Controller Motherboard Replacement: adım 4, 2 resimden 1. Afterglow Wireless PS3 Controller Motherboard Replacement: adım 4, 2 resimden 2.
    • Detach the main motherboard fom the front pate by carefully pulling it off.
    • Be careful of the trigger buttons when pulling out the motherboard. The bottons have mini-motherboards secured in place on the front plate. Carefully pull these out.
  5. Afterglow Wireless PS3 Controller Motherboard Replacement: adım 5, 2 resimden 1. Afterglow Wireless PS3 Controller Motherboard Replacement: adım 5, 2 resimden 2.
    • Remove two button padding from the back of motherboard.
  6. Afterglow Wireless PS3 Controller Motherboard Replacement: adım 6, 2 resimden 1. Afterglow Wireless PS3 Controller Motherboard Replacement: adım 6, 2 resimden 2.
    • Desolder the four button connections from the motherboard.
    • Desolder the joy stick connections located on the front.
Sonuç
Natalie Cox
207 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S19-G5, Hoffman Spring 2017 USF Tampa, Team S19-G5, Hoffman Spring 2017 üyesi
USFT-HOFFMAN-S17S19G5
4 Üyeler
14 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 45
Her zaman: 1,073
