Ana içeriğe geç
Air Hog Smash Bots Motor Replacement
Neye ihtiyacın var
  1. Air Hog Smash Bots Motor Replacement, Batteries: adım 1, 1 resimden 1.
    • Using the Phillips #0 screwdriver to remove the 8 mm screw.
  2. Air Hog Smash Bots Motor Replacement: adım 2, 1 resimden 1.
    • Lift and slide the batter cover away from the tab holding it in place at the bottom.
  3. Air Hog Smash Bots Motor Replacement: adım 3, 1 resimden 1.
    • Remove the 3 AAA batteries.
  4. Air Hog Smash Bots Motor Replacement, External Casing: adım 4, 2 resimden 1. Air Hog Smash Bots Motor Replacement, External Casing: adım 4, 2 resimden 2.
    • Using a Phillip #0 screwdriver to remove the eight 8 mm screws.
  5. Air Hog Smash Bots Motor Replacement: adım 5, 2 resimden 1. Air Hog Smash Bots Motor Replacement: adım 5, 2 resimden 2.
    • Remove the upper armor of the Smash Bot.
  6. Air Hog Smash Bots Motor Replacement: adım 6, 1 resimden 1.
    • Hold the upper body and slide out the bottom half of the Smash Bot.
    • The motor extends from the lower-body into the upper-body. Be careful to not damage the motor.
  7. Air Hog Smash Bots Motor Replacement: adım 7, 1 resimden 1.
    • Peel back the four decal stickers that hold the front and back of the bot together.
  8. Air Hog Smash Bots Motor Replacement: adım 8, 2 resimden 1. Air Hog Smash Bots Motor Replacement: adım 8, 2 resimden 2.
    • Use the plastic opening tool to pry the front and back of the lower body apart.
    • Carefully remove the back of the bot from the front.
  9. Air Hog Smash Bots Motor Replacement, Motor: adım 9, 2 resimden 1. Air Hog Smash Bots Motor Replacement, Motor: adım 9, 2 resimden 2.
    • Using the Phillips #0 screwdriver, remove six 4.75mm screws.
  10. Air Hog Smash Bots Motor Replacement: adım 10, 1 resimden 1.
    • Use the soldering iron to remove the blue and green wire from the motor casing. Directions on how to solder can be found here.
Sonuç
Brittany Frecker
542 İtibar
4 adet Kılavuz yazıldı
Ekip
IUPUI, Team 1-1, Baechle Spring 2016 IUPUI, Team 1-1, Baechle Spring 2016 üyesi
IUPUI-BAECHLE-S16S1G1
4 Üyeler
14 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 174
