Ana içeriğe geç
Alcatel One Touch Evolve 2 Rear Speaker Replacement
Neye ihtiyacın var
  1. Alcatel One Touch Evolve 2 Rear Speaker Replacement, Back Frame: adım 1, 3 resimden 1. Alcatel One Touch Evolve 2 Rear Speaker Replacement, Back Frame: adım 1, 3 resimden 2. Alcatel One Touch Evolve 2 Rear Speaker Replacement, Back Frame: adım 1, 3 resimden 3.
    • Turn off the phone before proceeding with disassembly to prevent shock and potential shorting of any electrical somponents.
    • Remove the back cover using one of the plastic opening tools and the slit in one of the corners.
    • Be gentle when prying so as to not wear out the tool.
  2. Alcatel One Touch Evolve 2 Rear Speaker Replacement: adım 2, 1 resimden 1.
    • Remove the battery using one of the plastic opening tools and the dome-shaped indent next to the battery face.
  3. Alcatel One Touch Evolve 2 Rear Speaker Replacement: adım 3, 1 resimden 1.
    • Unscrew the four 4mm JIS screws in each corner using the J000 screwdriver head. Turn the screws counter-clockwise to loosen.
  4. Alcatel One Touch Evolve 2 Rear Speaker Replacement: adım 4, 3 resimden 1. Alcatel One Touch Evolve 2 Rear Speaker Replacement: adım 4, 3 resimden 2. Alcatel One Touch Evolve 2 Rear Speaker Replacement: adım 4, 3 resimden 3.
    • Insert a plastic or metal spudger between the front cover and rear frame in one of the areas indicated by the red squares and gently pry the rear frame loose. Repeat the process all the way around the phone until the rear frame comes loose.
  5. Alcatel One Touch Evolve 2 Rear Speaker Replacement: adım 5, 2 resimden 1. Alcatel One Touch Evolve 2 Rear Speaker Replacement: adım 5, 2 resimden 2.
    • Pull the rear frame off with your hands.
  6. Alcatel One Touch Evolve 2 Rear Speaker Replacement, Rear Speaker: adım 6, 1 resimden 1.
    • Gently loosen the rear speaker by using one of the plastic opening tools and prying the speaker off its metal base.
    • The adhesive holding the speaker to the base may be strong depending on the age and condition of the phone. Adjust your prying force if necessary.
  7. Alcatel One Touch Evolve 2 Rear Speaker Replacement: adım 7, 1 resimden 1.
    • De-solder the black and red wires of the speaker using a soldering tool.
    • If you need instructions on how to solder/desolder electronic connections, here is a link to the Soldering Technique Guide
Sonuç
Bir başkası bu kılavuzu tamamladı.
Andrew Bai
634 İtibar
5 adet Kılavuz yazıldı
Ekip
IUPUI, Team 1-3, Baechle Spring 2017 IUPUI, Team 1-3, Baechle Spring 2017 üyesi
IUPUI-BAECHLE-S17S1G3
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 8
Her zaman: 449
