Giriş
A faulty motherboard could cause many problems as it is the core of the device. This guide will show you how to replace the motherboard and should fix a whole host of problems you may be having.
Neye ihtiyacın var
Begin working by using the plastic opening tool to remove the back cover of your Alcatel One Touch Pop 7. Opening the flap as shown in the picture will give you an easier start.
Pull the copper ribbon cable from the tab. It should be easily removed, as the ZIF connector is the only thing holding it in place.
Next up is removing the volume button assembly. Another easy removal, simply pull the assembly away from the device and you're done with the removal process.
Bu adımda kullanılan alet:Tweezers$4.99
The camera is in the top left corner of the tablet. To begin removal, use the tweezers to gently disconnect the ribbon cable attached to the camera.
What do I do if I try to open my camera and it says “can't connect to camera, please close apps that may use camera or flash light"?
Using the tweezers, pull the WIFI Antenna away from the motherboard and the wireless card.
We now need to remove 3 ZIF connectors, all located in the bottom right quadrant. The order they are disconnected doesn't matter.
3 farklı kişi bu kılavuzu tamamladı.
1Rehber Yorum
do you think i could find a controller board for this lcd screen? so i can give it a second life email me if you willing to help me santiproxgamerxd1@gmail.com. Thanks!
