Ana içeriğe geç
Alcatel Pop 4 Plus Headphone Jack Replacement
Neye ihtiyacın var
  1. Alcatel Pop 4 Plus Headphone Jack Replacement, Headphone Jack: adım 1, 3 resimden 1. Alcatel Pop 4 Plus Headphone Jack Replacement, Headphone Jack: adım 1, 3 resimden 2. Alcatel Pop 4 Plus Headphone Jack Replacement, Headphone Jack: adım 1, 3 resimden 3.
    • Begin by removing the back of the phone. Press your nail or a thin object in the bottom right-hand corner of the phone and gently press to release the back of the phone from the front.
  2. Alcatel Pop 4 Plus Headphone Jack Replacement: adım 2, 3 resimden 1. Alcatel Pop 4 Plus Headphone Jack Replacement: adım 2, 3 resimden 2. Alcatel Pop 4 Plus Headphone Jack Replacement: adım 2, 3 resimden 3.
    • Remove seventeen 1.2mm screws from the phone's mid-frame using the Phillips #000 screwdriver.
  3. Alcatel Pop 4 Plus Headphone Jack Replacement: adım 3, 2 resimden 1. Alcatel Pop 4 Plus Headphone Jack Replacement: adım 3, 2 resimden 2.
    • Once the screws have been taken out, remove the mid-frame protecting the phone's electronics by using a fingernail or tool to pry it off.
  4. Alcatel Pop 4 Plus Headphone Jack Replacement: adım 4, 3 resimden 1. Alcatel Pop 4 Plus Headphone Jack Replacement: adım 4, 3 resimden 2. Alcatel Pop 4 Plus Headphone Jack Replacement: adım 4, 3 resimden 3.
    • Disconnect the battery from the motherboard and remove it.
  5. Alcatel Pop 4 Plus Headphone Jack Replacement: adım 5, 2 resimden 1. Alcatel Pop 4 Plus Headphone Jack Replacement: adım 5, 2 resimden 2.
    • Unhook the USB ribbon from the motherboard.
  6. Alcatel Pop 4 Plus Headphone Jack Replacement: adım 6, 2 resimden 1. Alcatel Pop 4 Plus Headphone Jack Replacement: adım 6, 2 resimden 2.
    • Disconnect the phone's ribbon cable from the mother board.
  7. Alcatel Pop 4 Plus Headphone Jack Replacement: adım 7, 2 resimden 1. Alcatel Pop 4 Plus Headphone Jack Replacement: adım 7, 2 resimden 2.
    • Disconnect the ribbon cable that binds the two motherboards together.
  8. Alcatel Pop 4 Plus Headphone Jack Replacement: adım 8, 2 resimden 1. Alcatel Pop 4 Plus Headphone Jack Replacement: adım 8, 2 resimden 2.
    • Remove the phone's rear camera from the motherboard.
  9. Alcatel Pop 4 Plus Headphone Jack Replacement: adım 9, 1 resimden 1.
    • Insert a flat tool at the edge of the phone and gently lift to remove the motherboard.
  10. Alcatel Pop 4 Plus Headphone Jack Replacement: adım 10, 3 resimden 1. Alcatel Pop 4 Plus Headphone Jack Replacement: adım 10, 3 resimden 2. Alcatel Pop 4 Plus Headphone Jack Replacement: adım 10, 3 resimden 3.
    • Locate the phone's headphone jack on the motherboard.
  11. Alcatel Pop 4 Plus Headphone Jack Replacement: adım 11, 3 resimden 1. Alcatel Pop 4 Plus Headphone Jack Replacement: adım 11, 3 resimden 2. Alcatel Pop 4 Plus Headphone Jack Replacement: adım 11, 3 resimden 3.
Sonuç
Garett Marler
202 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 3
Her zaman: 165
