Ana içeriğe geç
Alienware 15 R2 Hard Drive Replacement
Jarid Williams
Jarid Williams ve 8 diğer katkıda bulunanlar
En son March 7, 2024 tarihinde güncellendi
10 dakika
Kolay
If you hard drive corrupts or you would like to add more storage to your Alienware 15 R2, follow this guide. When working with computers, always make sure to unplug your computer and ground yourself before reaching inner components so you don’t accidentally release an electrical charge into the sensitive technology. The discharge could potentially damage your computer’s internals.
Neye ihtiyacın var
Tamir Setleri
Bu kitler, bu kılavuzu tamamlamak için gereken tüm parçaları ve araçları içerir.
Parçalar
Aletler
Daha fazlasını göster…
  1. Alienware 15 R2 Hard Drive Replacement, Hard Drive: adım 1, 3 resimden 1. Alienware 15 R2 Hard Drive Replacement, Hard Drive: adım 1, 3 resimden 2. Alienware 15 R2 Hard Drive Replacement, Hard Drive: adım 1, 3 resimden 3.
    Bu adımda kullanılan alet:
    Anti-Static Wrist Strap
    $7.95
    • Place laptop upside down with the hinge facing you, then remove the two 9.0 mm Phillips #0 screws located in the center of the rear panel.
    • Remove the rear panel by using the iFixit opening tool to separate it from the back of the laptop.
    • Be sure to use your Anti-Static wrist strap for this process. Hard drives are susceptible to static damage!
  2. Alienware 15 R2 Hard Drive Replacement: adım 2, 2 resimden 1. Alienware 15 R2 Hard Drive Replacement: adım 2, 2 resimden 2.
    • Use the iFixit opening tool to disconnect the battery cable.
  3. Alienware 15 R2 Hard Drive Replacement: adım 3, 2 resimden 1. Alienware 15 R2 Hard Drive Replacement: adım 3, 2 resimden 2.
    • Use the T9 Torx bit to remove the screws on the hard drive cover.
  4. Alienware 15 R2 Hard Drive Replacement: adım 4, 2 resimden 1. Alienware 15 R2 Hard Drive Replacement: adım 4, 2 resimden 2.
    • Firmly pull on the plastic tab to remove connector from motherboard and remove the hard drive from it's slot.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 16
Son 30 gün: 49
Her zaman: 1,617
