Ana içeriğe geç
Alienware Aurora M9700 Hard Drive Replacement
Neye ihtiyacın var
  1. Alienware Aurora M9700 Hard Drive Replacement, Hard Drive: adım 1, 1 resimden 1.
    • Turn laptop upside down so you're looking at the bottom side of the laptop.
  2. Alienware Aurora M9700 Hard Drive Replacement: adım 2, 3 resimden 1. Alienware Aurora M9700 Hard Drive Replacement: adım 2, 3 resimden 2. Alienware Aurora M9700 Hard Drive Replacement: adım 2, 3 resimden 3.
    • At the bottom left corner, locate the square battery pack with the sliding unlock emblem above it.
    • Slide the lock to the right to unlock the battery pack.
    • Once it's unlocked the battery will release.
    • Lift the battery, removing it from its compartment.
  3. Alienware Aurora M9700 Hard Drive Replacement: adım 3, 3 resimden 1. Alienware Aurora M9700 Hard Drive Replacement: adım 3, 3 resimden 2. Alienware Aurora M9700 Hard Drive Replacement: adım 3, 3 resimden 3.
    • At the bottom right corner, locate the two hard drives labeled 1 and 2.
    • Remove the screws located on top of the hard drives slots.
    • Once screws are removed from each hard drive, slide both hard drives out of the slot.
  4. Alienware Aurora M9700 Hard Drive Replacement: adım 4, 3 resimden 1. Alienware Aurora M9700 Hard Drive Replacement: adım 4, 3 resimden 2. Alienware Aurora M9700 Hard Drive Replacement: adım 4, 3 resimden 3.
    • Each hard drive is attached to a cover which contains 4 screws located on all 4 corners of the hard drive.
    • Remove each of the 4 screws on both hard drive covers.
    • Once both covers are removed only the original hard drive will remain.
  5. Alienware Aurora M9700 Hard Drive Replacement: adım 5, 3 resimden 1. Alienware Aurora M9700 Hard Drive Replacement: adım 5, 3 resimden 2. Alienware Aurora M9700 Hard Drive Replacement: adım 5, 3 resimden 3.
    • Secure the new hard drive to the original hard drive cover, insert the screws on all 4 corners of the hard drive cover.
    • Complete this process for both hard drives. (Optional: if installing two drives.)
Sonuç
Jasmine Anchondo
679 İtibar
5 adet Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 4
Her zaman: 452
