Ana içeriğe geç
Alldaymall A88X Battery Replacement
Neye ihtiyacın var
    1. Alldaymall A88X Battery Replacement, Alldaymall A88X Back Cover: adım 1, 3 resimden 1. Alldaymall A88X Battery Replacement, Alldaymall A88X Back Cover: adım 1, 3 resimden 2. Alldaymall A88X Battery Replacement, Alldaymall A88X Back Cover: adım 1, 3 resimden 3.
      • Using a plastic opening tool, carefully pry the device apart. Make your way around the entire perimeter of the device and carefully place the two panels next to each other.
      • After the panels are separated, watch out for the speaker on the rear panel as it's wire is rather short.
      • When separating the panels keep an eye out for the power button and volume rocker as they can be dislodged.
      FixBot'a Sor
      Yorum Ekle
    2. Alldaymall A88X Battery Replacement: adım 2, 1 resimden 1.
      Bu adımda kullanılan alet:
      • Grip the speaker from the sides with your fingers or a pair of tweezers and slowly begin to remove it from the rear panel.
      • When removing the speaker, make sure not to disconnect the wires in any way.
      • After the speaker has been removed, place the rear panel aside.
      FixBot'a Sor
      Yorum Ekle
    1. Alldaymall A88X Battery Replacement, Battery: adım 3, 3 resimden 1. Alldaymall A88X Battery Replacement, Battery: adım 3, 3 resimden 2. Alldaymall A88X Battery Replacement, Battery: adım 3, 3 resimden 3.
      • Carefully separate the speaker wire from the tape and proceed to peel the tape off in an upwards direction.
      • The tape we are removing covers a number of connections on the motherboard. Be extra careful not to server any of these.
      FixBot'a Sor
      Yorum Ekle
    2. Alldaymall A88X Battery Replacement: adım 4, 3 resimden 1. Alldaymall A88X Battery Replacement: adım 4, 3 resimden 2. Alldaymall A88X Battery Replacement: adım 4, 3 resimden 3.
      • Using a nylon spudger, slowly work your way underneath the battery separating it from the panel beneath.
      • After the battery is separated from the panel make sure to place it face down above the tablet itself.
      • Throughout the removal process keep an eye on the battery's wires and make sure they do not break.
      FixBot'a Sor
      Yorum Ekle
    3. Alldaymall A88X Battery Replacement: adım 5, 2 resimden 1. Alldaymall A88X Battery Replacement: adım 5, 2 resimden 2.
      • Desolder the wires that connect the battery to the motherboard.
      FixBot'a Sor
      Yorum Ekle
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Alex
101 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 4-1, Lacy Spring 2016 USF Tampa, Team 4-1, Lacy Spring 2016 üyesi
USFT-LACY-S16S4G1
4 Üyeler
16 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 37
Her zaman: 1,621
