Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Using a plastic opening tool, carefully pry the device apart. Make your way around the entire perimeter of the device and carefully place the two panels next to each other.
Bu adımda kullanılan alet:Tweezers$4.99-
Grip the speaker from the sides with your fingers or a pair of tweezers and slowly begin to remove it from the rear panel.
After the speaker has been removed, place the rear panel aside.
Carefully separate the speaker wire from the tape and proceed to peel the tape off in an upwards direction.
Using a nylon spudger, slowly work your way underneath the battery separating it from the panel beneath.
After the battery is separated from the panel make sure to place it face down above the tablet itself.
Desolder the wires that connect the battery to the motherboard.
4 farklı kişi bu kılavuzu tamamladı.
