Giriş
The Alldaymall A88X has a 0.3 MP forward facing camera and a 2.0 MP rear facing camera. They are mounted on to the back panel. This guide will walk you through the process of removing the existing cameras and installing new ones.
Neye ihtiyacın var
Using a plastic opening tool, carefully pry the device apart. Make your way around the entire perimeter of the device and carefully place the two panels next to each other.
Carefully separate the speaker wire from the tape and proceed to peel the tape off in an upwards direction.
Using a nylon spudger, slowly work your way underneath the battery separating it from the panel beneath.
After the battery is separated from the panel make sure to place it face down above the tablet itself.
