Ana içeriğe geç
Alldaymall A88X LCD Screen Replacement
Neye ihtiyacın var
  1. Alldaymall A88X LCD Screen Replacement, Alldaymall A88X Back Cover: adım 1, 3 resimden 1. Alldaymall A88X LCD Screen Replacement, Alldaymall A88X Back Cover: adım 1, 3 resimden 2. Alldaymall A88X LCD Screen Replacement, Alldaymall A88X Back Cover: adım 1, 3 resimden 3.
    • Using a plastic opening tool, carefully pry the device apart. Make your way around the entire perimeter of the device and carefully place the two panels next to each other.
    • After the panels are separated, watch out for the speaker on the rear panel as it's wire is rather short.
    • When separating the panels keep an eye out for the power button and volume rocker as they can be dislodged.
  2. Alldaymall A88X LCD Screen Replacement: adım 2, 1 resimden 1.
    • Grip the speaker from the sides with your fingers or a pair of tweezers and slowly begin to remove it from the rear panel.
    • When removing the speaker, make sure not to disconnect the wires in any way.
    • After the speaker has been removed, place the rear panel aside.
  3. Alldaymall A88X LCD Screen Replacement, Speaker: adım 3, 3 resimden 1. Alldaymall A88X LCD Screen Replacement, Speaker: adım 3, 3 resimden 2. Alldaymall A88X LCD Screen Replacement, Speaker: adım 3, 3 resimden 3.
    • Carefully separate the speaker wire from the tape and proceed to peel the tape off in an upwards direction.
    • The tape we are removing covers a number of connections on the motherboard. Be extra careful not to sever any of these.
  4. Alldaymall A88X LCD Screen Replacement: adım 4, 3 resimden 1. Alldaymall A88X LCD Screen Replacement: adım 4, 3 resimden 2. Alldaymall A88X LCD Screen Replacement: adım 4, 3 resimden 3.
    • Using a pair of tweezers, begin separating the tape downwards from the back panel.
    • Pull the tape away from the wire bundle beneath.
    • Isolate the wire running from the speaker to the motherboard.
  5. Alldaymall A88X LCD Screen Replacement: adım 5, 3 resimden 1. Alldaymall A88X LCD Screen Replacement: adım 5, 3 resimden 2. Alldaymall A88X LCD Screen Replacement: adım 5, 3 resimden 3.
    • Desolder the speaker wires from the motherboard.
  6. Alldaymall A88X LCD Screen Replacement, Camera: adım 6, 3 resimden 1. Alldaymall A88X LCD Screen Replacement, Camera: adım 6, 3 resimden 2. Alldaymall A88X LCD Screen Replacement, Camera: adım 6, 3 resimden 3.
    • Using a nylon spudger, slowly work your way underneath the battery separating it from the panel beneath.
    • After the battery is separated from the panel make sure to place it face down above the tablet itself.
    • Throughout the removal process keep an eye on the battery's wires and make sure they do not break.
  7. Alldaymall A88X LCD Screen Replacement: adım 7, 2 resimden 1. Alldaymall A88X LCD Screen Replacement: adım 7, 2 resimden 2.
    • Desolder the wires that connect the battery to the motherboard.
  8. Alldaymall A88X LCD Screen Replacement: adım 8, 2 resimden 1. Alldaymall A88X LCD Screen Replacement: adım 8, 2 resimden 2.
    • Using a pair of tweezers begin to peel the tape covering the ribbon cable on the motherboard.
  9. Alldaymall A88X LCD Screen Replacement: adım 9, 3 resimden 1. Alldaymall A88X LCD Screen Replacement: adım 9, 3 resimden 2. Alldaymall A88X LCD Screen Replacement: adım 9, 3 resimden 3.
    • Using a pair of tweezers begin to peel the antenna from the metal panel.
    • Work your way down until the antenna is completely removed.
    • Be careful not deform the antenna or sever its connection.
  10. Alldaymall A88X LCD Screen Replacement: adım 10, 1 resimden 1.
    • Using a pair of tweezers remove the tape securing the cameras to the back panel.
  11. Alldaymall A88X LCD Screen Replacement: adım 11, 1 resimden 1.
    • Using a plastic opening tool lift up the flap on the ribbon cable receptacle.
  12. Alldaymall A88X LCD Screen Replacement: adım 12, 2 resimden 1. Alldaymall A88X LCD Screen Replacement: adım 12, 2 resimden 2.
    • Using a pair of tweezers remove the camera assembly from its housing and its receptacles.
  13. Alldaymall A88X LCD Screen Replacement, Motherboard: adım 13, 3 resimden 1. Alldaymall A88X LCD Screen Replacement, Motherboard: adım 13, 3 resimden 2. Alldaymall A88X LCD Screen Replacement, Motherboard: adım 13, 3 resimden 3.
    • Use a plastic opening tool to pull out the black knobs on both sides of the ribbon cable receptacle.
    • Using a pair of tweezers remove the ribbon cable from its receptacle.
  14. Alldaymall A88X LCD Screen Replacement: adım 14, 3 resimden 1. Alldaymall A88X LCD Screen Replacement: adım 14, 3 resimden 2. Alldaymall A88X LCD Screen Replacement: adım 14, 3 resimden 3.
    • Now on the left ribbon cable use a plastic opening tool to pull out the black knobs on both sides of the ribbon cable receptacle.
  15. Alldaymall A88X LCD Screen Replacement: adım 15, 2 resimden 1. Alldaymall A88X LCD Screen Replacement: adım 15, 2 resimden 2.
    • Desolder the wires that connect the backlight to the motherboard.
  16. Alldaymall A88X LCD Screen Replacement: adım 16, 3 resimden 1. Alldaymall A88X LCD Screen Replacement: adım 16, 3 resimden 2. Alldaymall A88X LCD Screen Replacement: adım 16, 3 resimden 3.
    • Using a PH0 screw bit unscrew the three 3mm screws securing the motherboard to the back panel.
  17. Alldaymall A88X LCD Screen Replacement: adım 17, 1 resimden 1.
    • Carefully lift up on the motherboard from its housing.
  18. Alldaymall A88X LCD Screen Replacement, LCD Screen and Touch Sensor Assembly: adım 18, 3 resimden 1. Alldaymall A88X LCD Screen Replacement, LCD Screen and Touch Sensor Assembly: adım 18, 3 resimden 2. Alldaymall A88X LCD Screen Replacement, LCD Screen and Touch Sensor Assembly: adım 18, 3 resimden 3.
    • Gently pry the brackets holding the touch sensor to the LCD Screen
    • Do not bend the touch sensor to much as it may shatter.
  19. Alldaymall A88X LCD Screen Replacement, LCD Screen: adım 19, 2 resimden 1. Alldaymall A88X LCD Screen Replacement, LCD Screen: adım 19, 2 resimden 2.
    • Set the touch sensor aside.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Drhaber
985 İtibar
7 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 4-1, Lacy Spring 2016 USF Tampa, Team 4-1, Lacy Spring 2016 üyesi
USFT-LACY-S16S4G1
4 Üyeler
16 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 5
Her zaman: 1,323
