Ana içeriğe geç
Altec Lansing inMotion iM9 Tweeter Replacement
Neye ihtiyacın var
  1. Altec Lansing inMotion iM9 Tweeter Replacement, Battery: adım 1, 1 resimden 1.
    • Gently push down on the two tabs at the top of the battery door.
    • While holding them down, slowly pull the door towards you.
  2. Altec Lansing inMotion iM9 Tweeter Replacement: adım 2, 1 resimden 1.
    • Once the door is open, use your hand to pull out the four batteries.
  3. Altec Lansing inMotion iM9 Tweeter Replacement, Volume and Power Buttons: adım 3, 2 resimden 1. Altec Lansing inMotion iM9 Tweeter Replacement, Volume and Power Buttons: adım 3, 2 resimden 2.
    • Pry off the control panel on top of the speaker using the metal spudger. You may need to use a lot of force.
    • Start in the middle and work your way around the perimeter.
  4. Altec Lansing inMotion iM9 Tweeter Replacement: adım 4, 2 resimden 1. Altec Lansing inMotion iM9 Tweeter Replacement: adım 4, 2 resimden 2.
    • Using a Phillips #1 screwdriver, remove the two 7mm screws that hold the volume button circuit board to the control panel.
    • Also remove the single 7mm screw from the power button circuit board on the opposite side.
    • There will be a little plastic piece under the eject button that you can just remove and set aside.
  5. Altec Lansing inMotion iM9 Tweeter Replacement: adım 5, 2 resimden 1. Altec Lansing inMotion iM9 Tweeter Replacement: adım 5, 2 resimden 2.
    • Desolder the three solders joints connecting the wires to the volume button circuit board.
    • Do the same to the power button circuit board on the other side (the board with only one screw).
    • Pull out the wires using a lot of force.
    • If you are not familiar or comfortable with soldering, use this guide
  6. Altec Lansing inMotion iM9 Tweeter Replacement, Case Opening: adım 6, 2 resimden 1. Altec Lansing inMotion iM9 Tweeter Replacement, Case Opening: adım 6, 2 resimden 2.
    • Gently pry open the silver plastic lining of the iPod dock using the plastic spudger.
    • It is best to start from the top or bottom, then work your way around if it has not popped out yet.
    • Remove the silver lining.
  7. Altec Lansing inMotion iM9 Tweeter Replacement: adım 7, 2 resimden 1. Altec Lansing inMotion iM9 Tweeter Replacement: adım 7, 2 resimden 2.
    • Pry open the metal mesh by working the plastic spudger around the inside of the mesh.
    • Once loose, lift up the metal mesh.
  8. Altec Lansing inMotion iM9 Tweeter Replacement: adım 8, 1 resimden 1.
    • Remove the fourteen 30mm screws with Phillips #1 Screwdriver.
    • Remove the 7mm screw with the Phillips #1 Screwdriver.
  9. Altec Lansing inMotion iM9 Tweeter Replacement: adım 9, 1 resimden 1.
    • Carefully separate the front and back case plates at a corner of the speaker.
    • Lots of cables are still connected, so be very gentle when separating case plates.
  10. Altec Lansing inMotion iM9 Tweeter Replacement: adım 10, 1 resimden 1.
    • Guide the white button cables through the hole on the top of speaker case.
  11. Altec Lansing inMotion iM9 Tweeter Replacement: adım 11, 1 resimden 1.
    • Use your fingers to peel the glue off of the red and black cables.
  12. Altec Lansing inMotion iM9 Tweeter Replacement: adım 12, 1 resimden 1.
    • Careful not to touch the green capacitors or you might shock yourself.
  13. Altec Lansing inMotion iM9 Tweeter Replacement, Tweeter: adım 13, 1 resimden 1.
    • Remove the speaker cables by desoldering the two solder joints on opposite sides of the tweeter.
  14. Altec Lansing inMotion iM9 Tweeter Replacement: adım 14, 1 resimden 1.
    • To fully remove the tweeter from the device, unscrew the two 7mm screws and the tweeter will be free.
  15. Altec Lansing inMotion iM9 Tweeter Replacement: adım 15, 1 resimden 1.
    • Follow the previous instructions to remove the second tweeter on the opposite side of the speaker.
Sonuç
Shaun Steele
264 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 17-33, Amido Winter 2015 Cal Poly, Team 17-33, Amido Winter 2015 üyesi
CPSU-AMIDO-W15S17G33
4 Üyeler
7 adet Kılavuz yazıldı
Bir Yorum
Where do you buy the replacement tweeters?
Fred Schneider - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 8
Son 30 gün: 10
Her zaman: 912
