Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Gently push down on the two tabs at the top of the battery door.
While holding them down, slowly pull the door towards you.
Once the door is open, use your hand to pull out the four batteries.
Pry off the control panel on top of the speaker using the metal spudger. You may need to use a lot of force.
Using a Phillips #1 screwdriver, remove the two 7mm screws that hold the volume button circuit board to the control panel.
Also remove the single 7mm screw from the power button circuit board on the opposite side.
Desolder the three solders joints connecting the wires to the volume button circuit board.
Do the same to the power button circuit board on the other side (the board with only one screw).
Pull out the wires using a lot of force.
Gently pry open the silver plastic lining of the iPod dock using the plastic spudger.
It is best to start from the top or bottom, then work your way around if it has not popped out yet.
Remove the silver lining.
Pry open the metal mesh by working the plastic spudger around the inside of the mesh.
Once loose, lift up the metal mesh.
Remove the fourteen 30mm screws with Phillips #1 Screwdriver.
Remove the 7mm screw with the Phillips #1 Screwdriver.
Carefully separate the front and back case plates at a corner of the speaker.
Guide the white button cables through the hole on the top of speaker case.
Use your fingers to peel the glue off of the red and black cables.
Using a Phillips #1 screwdriver, remove the two 7mm screws from the filter.
Repeat the previous step on the other side of the speaker. There are two more 7mm screws on the filter mirroring the first.
Using the Phillips #1 screwdriver, remove the four 10mm screws from the corners of the motherboard.
On the back side of the motherboard, pry out the connector to the filter using the plastic spudger. You will have to use a lot of force.
Pry out the second connect to the filter similarly.
Desolder the two battery connections from the motherboard.
Use the pointed end of the plastic spudger to pry the glue off of the iPod dock. You will probably have to use some force.
Unlock the ribbon cable dock by pressing down on the two tabs at the bottom of the dock.
Detach the copper ribbon cable by gently pulling it down, freeing the motherboard completely.
To remove the iPod Dock, unscrew the four 8mm screws located on the corners of the dock casing using the Phillips #1 screwdriver.
2 farklı kişi bu kılavuzu tamamladı.
