Ana içeriğe geç
Alternative Opening Procedure
Donald Todd
Donald Todd ve 4 diğer katkıda bulunanlar
En son February 19, 2016 tarihinde güncellendi
15 - 30 dakika
Orta
Öne Çıkan Kılavuzlar
Topluluk-Katkılı Kılavuz
Prying the case open will inevitably cause damage. This method disengages the catches to allow the case to be easily opened by hand.
The technique is probably applicable to the Intel Mini which has similar catches, but has not been tried.
  1. Alternative Opening Procedure, Alternative Opening Procedure: adım 1, 1 resimden 1.
    • Instead of a putty knife a dozen or more 1-1/2" pins are required.
  2. Alternative Opening Procedure: adım 2, 2 resimden 1. Alternative Opening Procedure: adım 2, 2 resimden 2.
    • With the computer upside down identify the apertures where the catches are located along either side and also at the front.
    • Insert the pins from the adjacent apertures between the wall and each catch. Be very careful to keep the pins against the case wall. This is more obvious from the second photo with the case removed.
  3. Alternative Opening Procedure: adım 3, 1 resimden 1.
    • Lift the case off from the back first.
    • Remove the pins from the main assembly.
    I found that I just wedged about eight butter knives around two sides and then to gently press them all at the same time and it kind of popped up.
    Antonella Francesca - Yanıt
Sonuç
Re-assembly does not require the pins. Place the case over the computer and press down evenly on the sides, not the middle. Ensure the back panel is correctly aligned before finally pushing home the catches.
16 farklı kişi bu kılavuzu tamamladı.
Donald Todd
528 İtibar
1 Kılavuz yazıldı
1Rehber Yorum
I've recently acquired a G4 Mini 1.33 "Silent Upgrade" on eBay and plan on opening up using your guide :) Thanks so very, VERY much!
Tyler Regas - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 17
Her zaman: 15,251
