Ana içeriğe geç
Aluratek ADMPF310F Speakers Replacement
Neye ihtiyacın var
  1. Aluratek ADMPF310F Speakers Replacement, Speakers: adım 1, 3 resimden 1. Aluratek ADMPF310F Speakers Replacement, Speakers: adım 1, 3 resimden 2. Aluratek ADMPF310F Speakers Replacement, Speakers: adım 1, 3 resimden 3.
    • Using the plastic opening tool pry off the clips all around the frame. You will hear a popping sound for every clip
    • Be sure not to pry to hard because you could crack or break the plastic facing of the device.
  2. Aluratek ADMPF310F Speakers Replacement: adım 2, 1 resimden 1.
    • Lift screen out of place so you can access the plugs that connect it.
    • Be careful not to pull the screen to far away when placing to the side, many fragile wires are connected.
  3. Aluratek ADMPF310F Speakers Replacement: adım 3, 2 resimden 1. Aluratek ADMPF310F Speakers Replacement: adım 3, 2 resimden 2.
    • Unplug both plugs for the speakers to the motherboard
  4. Aluratek ADMPF310F Speakers Replacement: adım 4, 2 resimden 1. Aluratek ADMPF310F Speakers Replacement: adım 4, 2 resimden 2.
    • Use plastic opening tool to pull out one of the speakers.
    • Then use your hand to take out the other speaker
  5. Aluratek ADMPF310F Speakers Replacement: adım 5, 1 resimden 1.
    • Disconnect the wires off of the old speakers and solder the old wires onto the new speakers.
Sonuç
Chris Belair
333 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 5-1, Martin Fall 2016 UMass Dartmouth, Team 5-1, Martin Fall 2016 üyesi
UMASSD-MARTIN-F16S5G1
3 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 7
Her zaman: 131
