Ana içeriğe geç
Amazon Echo Show 2nd Gen Speaker Replacement
Neye ihtiyacın var
  1. Amazon Echo Show 2nd Gen Speaker Replacement, Sound Card: adım 1, 3 resimden 1. Amazon Echo Show 2nd Gen Speaker Replacement, Sound Card: adım 1, 3 resimden 2. Amazon Echo Show 2nd Gen Speaker Replacement, Sound Card: adım 1, 3 resimden 3.
    • Unscrew the white case using the TR1 screwdriver bit to remove the 4mm screws.
    • Pull on the top until the case becomes fully dislodged.
  2. Amazon Echo Show 2nd Gen Speaker Replacement: adım 2, 2 resimden 1. Amazon Echo Show 2nd Gen Speaker Replacement: adım 2, 2 resimden 2.
    • Pull out the two white plugs by firmly grasping them and pulling in a downward motion until they become disconnected.
  3. Amazon Echo Show 2nd Gen Speaker Replacement: adım 3, 1 resimden 1.
    • Unscrew the 4mm, red-marked screws with the TR6 screwdriver bit.
    • Detach the ribbon from the circuit board by grasping from the top of the ribbon and pulling away from the board.
  4. Amazon Echo Show 2nd Gen Speaker Replacement: adım 4, 3 resimden 1. Amazon Echo Show 2nd Gen Speaker Replacement: adım 4, 3 resimden 2. Amazon Echo Show 2nd Gen Speaker Replacement: adım 4, 3 resimden 3.
    • Unscrew the red-marked, 4mm screws with the J1 screwdriver bit.
    • Carefully slide the sound card up and out of the black casing.
  5. Amazon Echo Show 2nd Gen Speaker Replacement, Speakers: adım 5, 3 resimden 1. Amazon Echo Show 2nd Gen Speaker Replacement, Speakers: adım 5, 3 resimden 2. Amazon Echo Show 2nd Gen Speaker Replacement, Speakers: adım 5, 3 resimden 3.
    • Firmly grasp the white trim of the front piece with one hand while the other pulls back on the black back portion of the device.
  6. Amazon Echo Show 2nd Gen Speaker Replacement: adım 6, 2 resimden 1. Amazon Echo Show 2nd Gen Speaker Replacement: adım 6, 2 resimden 2.
    • Unscrew all the indicated screws with the screwdriver.
    • Carefully remove the plate from the device.
  7. Amazon Echo Show 2nd Gen Speaker Replacement: adım 7, 3 resimden 1. Amazon Echo Show 2nd Gen Speaker Replacement: adım 7, 3 resimden 2. Amazon Echo Show 2nd Gen Speaker Replacement: adım 7, 3 resimden 3.
    • After unscrewing the speakers, gently pull out the foam covered attachment indicated in the orange box.
  8. Amazon Echo Show 2nd Gen Speaker Replacement: adım 8, 1 resimden 1.
    • Insert the white circuit box into the back plate the old speaker was removed from as indicated in he orange box.
    • Repeat on the other speaker if needed.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Bir Yorum
Where do I get replacement speakers at?
John Henry - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 28
Her zaman: 375
