Ana içeriğe geç
Amazon Fire HD 8 Screen Replacement
Neye ihtiyacın var
    1. Amazon Fire HD 8 Screen Replacement, Screen: adım 1, 2 resimden 1. Amazon Fire HD 8 Screen Replacement, Screen: adım 1, 2 resimden 2.
      • Heat the edges of the screen with a heat gun on the lowest setting by using sweeping motions from about 8-10 inches away.
      • Make sure you use sweeping motions with the heat gun, instead of hovering over one area.
      FixBot'a Sor
      Yorum Ekle
    2. Amazon Fire HD 8 Screen Replacement: adım 2, 1 resimden 1.
      • After 1-2 minutes, use a plastic opening tool to pry the screen loose. Start at the top right corner and gently pry the screen from the device.
      • Be careful not to bend the screen by pushing it too far from the rest of the device.
      FixBot'a Sor
      Yorum Ekle
    3. Amazon Fire HD 8 Screen Replacement: adım 3, 3 resimden 1. Amazon Fire HD 8 Screen Replacement: adım 3, 3 resimden 2. Amazon Fire HD 8 Screen Replacement: adım 3, 3 resimden 3.
      • Slide a plastic opening tool and spudger along the underside of the screen using enough force to peel the screen and the adhesive strip from the other half of the device.
      • Be mindful of the orange cable connecting the screen to the mid-bottom of the device.
      FixBot'a Sor
      Yorum Ekle
    4. Amazon Fire HD 8 Screen Replacement: adım 4, 3 resimden 1. Amazon Fire HD 8 Screen Replacement: adım 4, 3 resimden 2. Amazon Fire HD 8 Screen Replacement: adım 4, 3 resimden 3.
      Bu adımda kullanılan alet:
      • To remove the screen from the device, use tweezers to gently pull the orange cable from its connection to the screen.
      FixBot'a Sor
      Yorum Ekle
Sonuç
28 farklı kişi bu kılavuzu tamamladı.
Dan Shimkus
1.238 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-3, Leahy Spring 2016 USF Tampa, Team 1-3, Leahy Spring 2016 üyesi
USFT-LEAHY-S16S1G3
4 Üyeler
17 adet Kılavuz yazıldı
19Kılavuz Yorumları
Thankyou so much!
Judie Buder @me.com - Yanıt Paylaş
Very nice, but even Amazon is not marketing the replacement screens.
Wendy Huntington Parker Fages - Yanıt Paylaş
True, but if you happen to find another dysfunctional Fire ( with an intact screen) you can always harvest the display from that one and put it on your functioning unit. Long shot. But that's why this repair guide is still helpful even though parts aren't readily available.
Kelsea Weber - Yanıt Paylaş
Fingers crossed Amazon offers more parts in the future! :)
I ordered one from Amazon yesterday. Supposed to be 2 day shipping. Certainly not the $12 cheepy from China, but hopefully it will actually be shipped and delivered to my house. Any item Ive ever ordered that ended up being shipped directly from China has never found its way to my house and ends up costing about a months delay in the fixing of whatever device i have taken on the responsibility of to try & repair for someone.
Worth the $29 i’m paying at Amazon
Kitty Morgan - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 63
Son 30 gün: 222
Her zaman: 76,830
