Ana içeriğe geç
Amazon Fire Max 11 Micro SD Card Replacement
Neye ihtiyacın var
    1. Amazon Fire Max 11 Micro SD Card Replacement, Micro SD Card: adım 1, 1 resimden 1.
      • Power off the device.
      FixBot'a Sor
      Yorum Ekle
    2. Amazon Fire Max 11 Micro SD Card Replacement: adım 2, 1 resimden 1.
      • Press a SIM card tray pin (or a paper clip if you do not have the pin) into the hole in the side of the SIM card tray to eject the tray.
      FixBot'a Sor
      Yorum Ekle
    3. Amazon Fire Max 11 Micro SD Card Replacement: adım 3, 2 resimden 1. Amazon Fire Max 11 Micro SD Card Replacement: adım 3, 2 resimden 2.
      • Remove the existing SIM card from the device.
      • Place the new SIM card in the slot of the SIM card tray in the direction indicated on the card.
      • Close the SIM card tray.
      FixBot'a Sor
      Yorum Ekle
Sonuç
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Bir başkası bu kılavuzu tamamladı.
Anthony Martins
522 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-3, Konn Spring 2024 UMass Dartmouth, Team 1-3, Konn Spring 2024 üyesi
UMASSD-KONN-S24S1G3
4 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 18
Son 30 gün: 60
Her zaman: 1,111
