Giriş
My remote had battery leakage damage. I attempted to disassemble to clean but prying was very forceful and I probably damaged it. Also, I found the battery damage was extensive inside.
Neye ihtiyacın var
Heat it a lot if you are trying to maintain it in working order because it seems the glue on the clasps was very strong. I probably broke mine taking it apart (but it didn't work anyway so I don't know).
It takes A LOT of force to pry this apart. I'm not sure it's possible without breaking the inside.
Very easy to remove with the #0 phillips screwdriver.
Once the screws are removed, all the pieces come out easily.
2Kılavuz Yorumları
Thanks for the teardown, new firestorm 4k has a couple of screws under the round wheel, but you can pop that off and the remove.
. I used a pair of pliers to just rip off the mic, it is surface mounted and comes away with the pads and remote still works. Small amount of glue on the inside.
Took my firestick apart and this is what I found it is nothin like my spare one I have,why does it look like it does?is it possibly being used for something else???I can also send pics
