Giriş
If your device is not working due to a faulty power cord, you can follow this guide to easily replace the faulty cord with a new one.
Neye ihtiyacın var
Place the plastic opening tool in the space between the rubber and the plastic case of the device.
Apply pressure by pushing upward on the case.
Separate the bottom square rubber piece from the case using the plastic opening tool until all clips are detached.
With the mother board back facing you locate the power cord port found on the far left end.
Locate the four soldering joints for the power cord port found on the top side of the mother board.
Desolder the joints of the power cord port to release it from the motherboard.
Place the new power cord port into its original location and solder its joints.
Use the iFixit soldering and desoldering guide.
6 farklı kişi bu kılavuzu tamamladı.
2Kılavuz Yorumları
Aonde compro essa fonte ? wagnerj957@gmail.com
Ola moro no Brasil minha fonte queimou aonde compro outra?
