Ana içeriğe geç
Amazon FireTV Stick Motherboard Replacement
Neye ihtiyacın var
  1. Amazon FireTV Stick Motherboard Replacement, Motherboard: adım 1, 2 resimden 1. Amazon FireTV Stick Motherboard Replacement, Motherboard: adım 1, 2 resimden 2.
    • Insert a plastic opening tool into the seam on either side of the device.
    • Side the plastic opening tools along the seam of the stick and pry the top half of the case away from the bottom.
    • Don't force the case apart. If you've successfully unhooked all of the clips, the case will be easy to remove.
  2. Amazon FireTV Stick Motherboard Replacement: adım 2, 2 resimden 1. Amazon FireTV Stick Motherboard Replacement: adım 2, 2 resimden 2.
    • Lift the back of the motherboard and slide it out of the case.
Sonuç
31 farklı kişi bu kılavuzu tamamladı.
Sami Uzzama
642 İtibar
2 adet Kılavuz yazıldı
Ekip
IUPUI, Team 2-3, Harley SU 2016 IUPUI, Team 2-3, Harley SU 2016 üyesi
IUPUI-HARLEY-SU16S2G3
4 Üyeler
14 adet Kılavuz yazıldı
13Kılavuz Yorumları
Where can you purchase a new motherboard for the TV stick?
Brandon Boykin - Yanıt
Where can you get a new mobo? Mine was defective from day one. Amazon thought it was the remote and replaced the remote. It still didn't work. When I contacted them to state this and get a new stick, they informed me they had refunded my purchase and I would just need to buy a new stick.They said I can through this one away. This was frustrating and being the tinkerer I am I want to get this thing to work now. If there is any info on any connections that I can reinforce that would be great too.
blindzen - Yanıt
My firestick has no sound and a little headphone icon pops up in the corner of my tv screen…how can i fix it??please heeeellllppp!!
Rzackery - Yanıt
Your TV sound is off, I think.
[deleted] -
Some issues are caused by the flexing of the Stick (being inserted & removed) around the HDMI connector internally, in addition to the Heat dissipation issues the Fire TV Stick is known for having……. I have just re-soldered the internal cracks around the HDMI connector on my Fire TV Stick & have replaced the Amazon provided USB power adaptor (which is 1.0 ampere) with another adaptor that I have (Which is 1.35 ampere) & the stick is now operating as well if not better than it ever has
Leigh Towers - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 11
Son 7 gün: 55
Son 30 gün: 341
Her zaman: 42,991
