Ana içeriğe geç
Anbernic RG35XXSP Speaker Replacement
Neye ihtiyacın var
  1. Anbernic RG35XXSP Speaker Replacement, Battery: adım 1, 3 resimden 1. Anbernic RG35XXSP Speaker Replacement, Battery: adım 1, 3 resimden 2. Anbernic RG35XXSP Speaker Replacement, Battery: adım 1, 3 resimden 3.
    • Power the device off before starting the disassembly process.
    • Close the device and turn it over so the bottom faces upward.
  2. Anbernic RG35XXSP Speaker Replacement: adım 2, 2 resimden 1. Anbernic RG35XXSP Speaker Replacement: adım 2, 2 resimden 2.
    • Use a Phillips #00 screwdriver to remove the single 5 mm screw securing the battery cover.
    • Lift the battery door and remove it.
  3. Anbernic RG35XXSP Speaker Replacement: adım 3, 2 resimden 1. Anbernic RG35XXSP Speaker Replacement: adım 3, 2 resimden 2.
    • Use a T6 Torx screwdriver to remove the four 5 mm screws.
    • Lift the whole back case with the battery from the device.
    • Don't pull it away because the battery is connected to the board.
  4. Anbernic RG35XXSP Speaker Replacement: adım 4, 3 resimden 1. Anbernic RG35XXSP Speaker Replacement: adım 4, 3 resimden 2. Anbernic RG35XXSP Speaker Replacement: adım 4, 3 resimden 3.
    • Remove the battery from the back compartment and fit it through the gap in the back case.
    • Put the plastic case aside for reassembly.
  5. Anbernic RG35XXSP Speaker Replacement: adım 5, 3 resimden 1. Anbernic RG35XXSP Speaker Replacement: adım 5, 3 resimden 2. Anbernic RG35XXSP Speaker Replacement: adım 5, 3 resimden 3.
    • Pinch the sides of the battery connector and slide it from the socket to disconnect the battery cable.
    • Remove the battery.
  6. Anbernic RG35XXSP Speaker Replacement, Speaker: adım 6, 2 resimden 1. Anbernic RG35XXSP Speaker Replacement, Speaker: adım 6, 2 resimden 2.
    • Lift up the green sheet of paper from the motherboard.
  7. Anbernic RG35XXSP Speaker Replacement: adım 7, 3 resimden 1. Anbernic RG35XXSP Speaker Replacement: adım 7, 3 resimden 2. Anbernic RG35XXSP Speaker Replacement: adım 7, 3 resimden 3.
    • Use a Phillips #00 screwdriver to remove the three 5 mm screws that secure the motherboard.
    • Lift up the motherboard from the main body and flip it to the other side to reveal the speaker.
  8. Anbernic RG35XXSP Speaker Replacement: adım 8, 1 resimden 1.
    • Remove the speaker from the device.
Sonuç
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
3 farklı kişi bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 10
Son 30 gün: 37
Her zaman: 240
