Ana içeriğe geç
Anker 2.4G Wireless Mouse Sensor Replacement
Neye ihtiyacın var
    1. Anker 2.4G Wireless Mouse Sensor Replacement, Sensor: adım 1, 1 resimden 1.
      • Using a spudger, carefully pry off the stickers to reveal the location of four screws.
      FixBot'a Sor
      Yorum Ekle
    2. Anker 2.4G Wireless Mouse Sensor Replacement: adım 2, 1 resimden 1.
      • Using your Phillips screwdriver, remove the four screws.
      FixBot'a Sor
      Yorum Ekle
    3. Anker 2.4G Wireless Mouse Sensor Replacement: adım 3, 2 resimden 1. Anker 2.4G Wireless Mouse Sensor Replacement: adım 3, 2 resimden 2.
      • Using a spudger, carefully pry apart the upper and lower housing of the mouse.
      • Make sure you are not using too much pressure, as you could warp the plastic.
      FixBot'a Sor
      Yorum Ekle
    4. Anker 2.4G Wireless Mouse Sensor Replacement: adım 4, 1 resimden 1.
      • Disconnect the wires from the white crimping headers.
      • Pull as far up on the wire as possible, but be careful to avoid ripping the wires.
      FixBot'a Sor
      Yorum Ekle
    5. Anker 2.4G Wireless Mouse Sensor Replacement: adım 5, 1 resimden 1.
      • Remove the scroll wheel from the motherboard by pulling it to the left.
      • This may take some force to remove. Make sure to pull it parallel to the board, instead of perpendicularly.
      FixBot'a Sor
      Yorum Ekle
    6. Anker 2.4G Wireless Mouse Sensor Replacement: adım 6, 1 resimden 1.
      Bu adımda kullanılan alet:
      Anti-Static Wrist Strap
      $7.95
      • Gently lift the motherboard away from the plastic housing.
      • Use an iFixit grounding strap or another antistatic measure to prevent sensitive components from electrostatic discharge during this step.
      FixBot'a Sor
      Yorum Ekle
    7. Anker 2.4G Wireless Mouse Sensor Replacement: adım 7, 1 resimden 1.
      • Desolder the six wires holding the I.C. in place to complete the sensor change.
      • Replace the broken sensor with the new sensor and solder back in place.
      • Make sure none of your solder connections are bridged as this can cause serious damage to your mouse.
      FixBot'a Sor
      Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Ryan
152 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 1-39, Maness Winter 2014 Cal Poly, Team 1-39, Maness Winter 2014 üyesi
CPSU-MANESS-W14S1G39
4 Üyeler
16 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 12
Son 30 gün: 52
Her zaman: 8,509
