Ana içeriğe geç
Anker SoundCore 2 Bluetooth Chip Replacement
Neye ihtiyacın var
    1. Anker SoundCore 2 Bluetooth Chip Replacement, Front Panel: adım 1, 2 resimden 1. Anker SoundCore 2 Bluetooth Chip Replacement, Front Panel: adım 1, 2 resimden 2.
      • Insert a spudger between the front panel and the body of the speaker.
      • Pry around the edges of the front panel with the spudger to pry it away from the speaker body.
      FixBot'a Sor
      Yorum Ekle
    1. Anker SoundCore 2 Bluetooth Chip Replacement, Motherboard: adım 2, 3 resimden 1. Anker SoundCore 2 Bluetooth Chip Replacement, Motherboard: adım 2, 3 resimden 2. Anker SoundCore 2 Bluetooth Chip Replacement, Motherboard: adım 2, 3 resimden 3.
      • Remove eight 10 mm screws from the speaker mount using a Phillips #0 screwdriver.
      • Insert a spudger in the gap between the speaker mount and speaker body to remove the speaker mount.
      • Use your hand to remove the speakers.
      FixBot'a Sor
      Yorum Ekle
    2. Anker SoundCore 2 Bluetooth Chip Replacement: adım 3, 3 resimden 1. Anker SoundCore 2 Bluetooth Chip Replacement: adım 3, 3 resimden 2. Anker SoundCore 2 Bluetooth Chip Replacement: adım 3, 3 resimden 3.
      • Remove the 10 mm screw that is holding the motherboard in place using a Phillips #0 screwdriver.
      • Flip up the motherboard and disconnect the cord that connects the motherboard and the battery.
      FixBot'a Sor
      Yorum Ekle
    1. Anker SoundCore 2 Bluetooth Chip Replacement, Bluetooth Chip: adım 4, 2 resimden 1. Anker SoundCore 2 Bluetooth Chip Replacement, Bluetooth Chip: adım 4, 2 resimden 2.
      • Desolder the bluetooth chip and solder a new one on the motherboard where the existing one was.
      • For help desoldering and soldering, follow this guide.
      FixBot'a Sor
      Yorum Ekle
Sonuç
1Rehber Yorum
My soundcore 2 will randomly peak in volume. It gets louder and then goes back to normal in random short bursts.
foxknight19 - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 15
Son 30 gün: 71
Her zaman: 2,995
