Ana içeriğe geç
Anker SoundCore 2 Charging Port Replacement
Neye ihtiyacın var
    1. Anker SoundCore 2 Charging Port Replacement, Front Panel: adım 1, 2 resimden 1. Anker SoundCore 2 Charging Port Replacement, Front Panel: adım 1, 2 resimden 2.
      • Insert a spudger between the front panel and the body of the speaker.
      • Pry around the edges of the front panel with the spudger to pry it away from the speaker body.
      FixBot'a Sor
      Yorum Ekle
    1. Anker SoundCore 2 Charging Port Replacement, Motherboard: adım 2, 3 resimden 1. Anker SoundCore 2 Charging Port Replacement, Motherboard: adım 2, 3 resimden 2. Anker SoundCore 2 Charging Port Replacement, Motherboard: adım 2, 3 resimden 3.
      • Remove eight 10 mm screws from the speaker mount using a Phillips #0 screwdriver.
      • Insert a spudger in the gap between the speaker mount and speaker body to remove the speaker mount.
      • Use your hand to remove the speakers.
      FixBot'a Sor
      Yorum Ekle
    2. Anker SoundCore 2 Charging Port Replacement: adım 3, 3 resimden 1. Anker SoundCore 2 Charging Port Replacement: adım 3, 3 resimden 2. Anker SoundCore 2 Charging Port Replacement: adım 3, 3 resimden 3.
      • Remove the 10 mm screw that is holding the motherboard in place using a Phillips #0 screwdriver.
      • Flip up the motherboard and disconnect the cord that connects the motherboard and the battery.
      FixBot'a Sor
      Yorum Ekle
    1. Anker SoundCore 2 Charging Port Replacement, Charging Port: adım 4, 2 resimden 1. Anker SoundCore 2 Charging Port Replacement, Charging Port: adım 4, 2 resimden 2.
      • Desolder the charging port from the motherboard and solder a new one on.
      • For help with soldering and desoldering, follow this guide.
      FixBot'a Sor
      Yorum Ekle
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
5Kılavuz Yorumları
Hello please what's the model of the ESD4 and C34 close to the charging port?
Abel Omeokwe - Yanıt Paylaş
Where can i get a replacement charging Port?
A K - Yanıt Paylaş
what's the micro usb port part number? I want to replace it but can't find info on it anywhere.
Tomasz Konwalski - Yanıt Paylaş
I've made the replacement, but with a spare type c port and...it's not working. Can someone help?
Delyan - Yanıt Paylaş
I use Anker OEM style replacement in my repair shop from eBay listing 254057783007
Perfect fit.
https://www.ebay.com/itm/254057783007
Good luck with the project
G.K. - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 26
Son 30 gün: 102
Her zaman: 5,467
