Ana içeriğe geç
Anker Soundcore Life Q20 Buttons Replacement
Neye ihtiyacın var
  1. Anker Soundcore Life Q20 Buttons Replacement, Ear Cushion: adım 1, 1 resimden 1.
    • Choose the desired ear cushion to replace.
    • Orient the headphones so that the side of the ear cushion is accessible.
    FixBot'a Sor
    Yorum Ekle
  2. Anker Soundcore Life Q20 Buttons Replacement: adım 2, 2 resimden 1. Anker Soundcore Life Q20 Buttons Replacement: adım 2, 2 resimden 2.
    • Wedge the iFixit opening tool into the groove where the ear cushion meets the base of the headphones.
    • Pry the ear cushion apart from the base.
    FixBot'a Sor
    Yorum Ekle
  3. Anker Soundcore Life Q20 Buttons Replacement: adım 3, 2 resimden 1. Anker Soundcore Life Q20 Buttons Replacement: adım 3, 2 resimden 2.
    • Repeat step 2 in a rotation around the ear cushion until it is fully detached from the base.
    FixBot'a Sor
    Yorum Ekle
  4. Anker Soundcore Life Q20 Buttons Replacement, Battery: adım 4, 3 resimden 1. Anker Soundcore Life Q20 Buttons Replacement, Battery: adım 4, 3 resimden 2. Anker Soundcore Life Q20 Buttons Replacement, Battery: adım 4, 3 resimden 3.
    • Use a Phillips #00 screwdriver to remove the four 10 mm screws from the cover.
    • Remove the cover to expose the battery.
    FixBot'a Sor
    Yorum Ekle
  5. Anker Soundcore Life Q20 Buttons Replacement: adım 5, 1 resimden 1.
    FixBot'a Sor
    Yorum Ekle
  6. Anker Soundcore Life Q20 Buttons Replacement, Buttons: adım 6, 1 resimden 1.
    • Using the Phillips #00 screwdriver, remove the two 7 mm screws from the green board.
    FixBot'a Sor
    Yorum Ekle
  7. Anker Soundcore Life Q20 Buttons Replacement: adım 7, 1 resimden 1.
    • Press the buttons as usual to pop them out of the base.
    • Gently pull the remaining tabs inside the base to disconnect the buttons.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 26
Her zaman: 407
