Giriş
Are the speakers on your Anker Soundcore Motion 3000 muffled, the audio coming in and out, or seemingly broken; causing the audio from your device to be distorted? All you need is a Phillips head screwdriver, your opening tool, and the replacement guide below to help with your problem.
Neye ihtiyacın var
Insert an opening tool into a seam between the grille and chassis.
Gently pry the grille up to begin disengaging the retaining clip.
Once a corner starts to lift, slowly slide the tool along the edge to loosen more of the grille.
Use a Phillips #0 screwdriver to remove all eight 11.5 mm screws that secure the driver housing.
With a Phillips #0 screwdriver, remove the four 7.5 mm screws that secure the driver.
Repeat the previous bullet for the other driver.
Gently lift off the drivers; the speakers may be slightly glued or stuck to the plastic plate so try not pull on the wiring attaching the components.
Disconnect each of the the two driver connectors from the motherboard.
Remove the drivers.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
